Jesse_Boyer
Car in question is my '02 Wagon. While running at highway speed, dip into the throttle and I noticed a strange noise. Noise follows RPM and only appears when I give the car 1/4-1/2 (estimated) throttle. Go mild on the the throttle and all is well, no noise.
Longblock is out of an '00 Automatic, complete with 11mm pump, 102k on the motor. Injectors are out of the '02 original motor. I did have to replace one of the tips with a used OEM 5sp tip I had in storage.
Compression is stellar; checked again this morning. 500+psi on all cylinders.
Starts instantly, idles perfect, drives perfect (other than this noise when giving more than 1/2-ish throttle.)
I've checked for exhaust leaks and can't see any evidence of a leak. All manifold nuts are tight, gaskets in place.
Injector mg/stroke deviation via VCDS ranges from -0.4, -0.1, etc. Seems normal.
No evidence of cam/lifter wear as of 1000 miles ago when I put the motor in the car.
Occurs with an EGR block-off plate between the EGR cooler and upper 90° hose, no difference.
If anyone thinks it could be an injector (or even the tip I replaced,) I can swap a 5sp injector from my daily-driver with each of the 1, 2, and 4 injectors this afternoon to eliminate the possibility. At a last resort, I'll swap the 11mm with a known-good 10mm (just not thrilled about it.)
suggestions extremely appreciated.
