Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old April 15th, 2018, 12:49   #16
BKmetz
Administrator, Member #10
BKmetz's Avatar
Fuel Economy: 50 MPG
Originally Posted by sonic reducer View Post
maybe my b4 Passat too but seems more risky and the payout is a lot lower.
Don't use anything but D2 in your B4. Even though the 1Z engine is the first generation TDI and is quite crude by today's technology, it can't handle WMO at all without severe damage. It can't really handle SVO or WVO either for that matter.
I put over 750k miles on my 2 B4s. In all those miles I only had to replace injectors in one car once at around ~300k miles, and a temperature sensor in the other at around ~300k miles.
Here is a photo I took of the inside of the fuel pump when I replaced the temperature sensor. This photo was taken in the parking lot at the 2006 Philly TDIFest. JasonTDI & I replaced the temp sensor. You can see the paper towels stuffed around the fuel pump to catch the spillage when we pulled the top off. If you use pump fuel and change your fuel filters when you're suppose to, this is what the fuel pump should always look like inside.
This is what the temperature sensor looks like.
Brian, 2015 Passat SE TDI 6MT
Kathy, 2014 Passat SE 2.5
Chris, 2015 Passat SEL TDI
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old January 14th, 2019, 21:57   #17
[486]
TDI(s): 02 golf ALH
With the sickly stink of vegetable oil coming from the pumps now that they've mandated biodiesel blending is making me think again on this. My #3 injector leaks a little externally, and the front of my engine looks like a neglected deep-fryer as a result. I'd do this to just get back to a proper petroleum based fuel.
Still running W85 in my ford, still showing good results there, and the tuning side of things is rather easy for me to bumble through. Just leery on possibly messing up my $400 set of nozzles... Though putting it that way makes it seem silly, as that's only 10 fillups or 6000 miles of driving.
May well be some development in this on my end. 12mm/de110 pump and DSS .360s should give enough fuel to compensate for the lower energy density.
Old January 23rd, 2019, 22:18   #18
[486]
TDI(s): 02 golf ALH
right now I'm at about 3 gal used lube oil, 1 g gasoline and 6 g diesel
Been running over-advanced timing, so it was very sluggish with proper diesel, but with the worse cetane of the waste oil the turbos seem to be lighting up a little earlier, almost as they were with the previous well-retarded timing and proper diesel. Gonna continue messing around with this, got a bucket that's premixed 4g of used ATF and 1g of gasoline that was destined for my truck which is parked for the winter, that'll be going in next when there's room, and the temperature's going to be down real low all next week so that'll be a good test for the starting side of things.
Old January 27th, 2019, 05:55   #19
WarmStart
TDI(s): TDI
When I had 1.6 IDI I run some time 50:50 diesel hydraulic oil. It had more power in low revs. But it wear out my injector pump. I didn't purify oil in any way.
Here are some ideas how to purify WMO:
https://sciencing.com/distill-motor-...l-7861173.html
https://usfiltermaxx.com/en/content/9-make-black-diesel
https://www.youtube.com/watch?v=zFNnoQyN7Zs
Few years ago there was much more info about black diesel.
If I would run it now I would use settling tanks and centrifuges to purify it.
WarmStart is offline   Reply With Quote
Old February 2nd, 2019, 20:30   #20
[486]
TDI(s): 02 golf ALH
Multiple days parked outside in -20 to -30F
Started every morning.
Diesel sucks, lube oil and gasoline is where it's at!
Old February 6th, 2019, 14:17   #21
erbilabuc
what car are you using this mixture on and what is your definition of "lube oil"
erbilabuc is offline   Reply With Quote
Old February 6th, 2019, 19:18   #22
[486]
TDI(s): 02 golf ALH
5w20 drain oil, alh with big honkin fuel system stuff and reasonably sized turbos
Old February 14th, 2019, 06:17   #23
Pat Dolan
Fuel Economy: 800km/1100km/tank
diesel WMO is black because it contains soot. Yes, you could be getting some deposits from the higher boiling point of the longer paraffin chains of vacuum distillates (lube oil base stock), but IMHO the big deal is that you will be gluing a lot of pure carbon (soot) into those deposits. Also, the additive package contains a lot of metallic compounds (especially zinc) that will make yet another deposit that the engine might no be so crazy about. You can not filter or centrifuge either of those out, just the big stuff.
I have run a lot of gensets on napthenic base stocks that are about 5 CSt @ 20C, and the ultimate limit seems to be carbon accumulation in exhaust side. Seem to scavenge well in combustion chamber. However, we have some very electronic engines on the farm that really do NOT like running anything but ULSD, so there are some definite limits to alternative fuels. BUT: that is no endorsement of WMO. I would want to see someone run a well known mix for many miles in any particular (all mechanical) engine and see a teardown for deposit characteristics before trying it in the very same engine (may 486's Ford/IHC IDI could be a test mule).
Of course, for literally junkyard engines, what have you got to loose? .... just as long as you tear down and report to us.
4L='14 Q7 TDI, B7='15TDI(buy back), B6='09 wagon gasser, A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, 2014 I, Porsche 924/M471 and a bunch of diesel trucks.
Pat Dolan is offline   Reply With Quote
Old February 14th, 2019, 19:33   #24
[486]
TDI(s): 02 golf ALH
rofl
motor that came with the $650 truck (at about 250k miles) got pulled out about 4 years and 2k miles later, it had been bubbling out the rad pretty good for the entire time I owned it, assumed it was head gasket. Cylinder wall was eaten through as these do. All 8 were sleeved and it was the worst rebuild I'd ever seen with the main bores beat like it'd been slung around with a chain through them. The problem cylinder had rust pitting in it so bad it's a wonder the piston rings hadn't caught on it.
The motor I put in, (a $600 craigslist deal) also seems to push coolant. It also hydrolocks itself if it stops at the right spot. rofl
I've given up on 7.3s, I'm halfway looking for a 6.9 as they don't have cylinder wall issues, but they're all long scrapped around here.
So yeah, your "literally junkyard engines" quip is understating the garbage that I drive. c:
ETA: oh right, on the buildup in the exhaust, is it coke?
I'd bet that would be more a problem on constant load stuff than an automotive engine where it can see periodic loading well beyond what you'd see on an industrial engine. My TDI sees the pyro pegged pretty often, and the truck is naturally aspirated (but showed no signs of any buildup in the exhaust manifolds) but the pyro on that's been broken long enough that I don't remember whereabout it ran.
Black Diesel skicat Fuels & Lubricants 17 September 26th, 2012 06:36
Diesel and Black Carbon Blonde Guy TDI (Diesel) Emissions 9 January 6th, 2011 21:52
New 2010 black diesel DGolder2 TDI 101 3 December 24th, 2010 22:16
has anyone tried black diesel ? bigwheels0 Fuels & Lubricants 7 August 22nd, 2007 17:28
Finally Here! black-Black-BLACK 2004 TDI Variant GETTIN_a_TDI Passat TDI Picture Gallery 14 October 13th, 2004 11:33
Page generated in 0.16213 seconds with 12 queries
[Output: 100.68 Kb. compressed to 87.05 Kb. by saving 13.63 Kb. (13.54%)]
