Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Eastern USA
Eastern USA Local discussions for those in the Eastern USA. (Vermont, New Hampshire, Massachusetts, Maine, Washington, DC. New York, New Jersey, Connecticut, Rhode Island, Delaware, Maryland, Pennsylvania, Virginia, West Virginia)
Old January 7th, 2019, 08:11   #1
mattboyd
Default TDI Mechanic Recommendations (between DC and Richmond)
All,
Infrequent poster here, but I'm looking for advice on someone who regularly works on TDIs). Mine is an 04 Jetta wagon. I bought it from a friend a couple years ago with 209k miles and am just about to hit 300k. When he had it it was meticulously dealer-maintained with Castrol Edge synthetic oil changes every 5k miles and a mostly "if you see something, fix it" approach. Since I've had it, I have done the majority of the maintenance myself including that same Castrol Edge oil change (although I stretch it to 10k miles since it is synthetic). I've replaced one axle and had the CV joints redone on the other, I did the front brakes for the first time in the car's lifetime at 255k miles and did rears for its second time at the same time. I had the dealer replace the cat back exhaust due to bottoming out on the muffler and causing a hole. I just had the steering rack replaced, and other than other normal maintenance (e.g.-fuel, air, and cabin filters) it's been pretty seamless.
Now it is time for a few big jobs:
i) Replace the original clutch
ii) Timing belt (and likely waterpump)
iii) Replace one of the rear calipers and e-brake cables (I might do this myself)
I'm looking for a fairly local mechanic in proximity to Fredericksburg, VA (mid-way between DC and Richmond). It could be an established independent shop or a moonlighting mechanic. I just am looking for someone with experience and a documented good reputation who I would trust more than the dealer network and who would be less expensive than the dealer. I also am looking for someone to look at what might be deferred maintenance that I have missed. Even potential for considering installing a taller 5th gear since we're in doing a clutch.
Thanks in advance for any advice.
-matt
mattboyd is offline   Reply With Quote
Old January 7th, 2019, 09:25   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Look HERE.
-George Bernard Shaw
Old January 12th, 2019, 18:37   #3
MKIInut
Matt see if Ninedee Golf TDI is still doing timing belt etc. He did one for me a few years ago and it was reasonably priced. I purchased all the parts and he did the work. He may be able to help you with the other things as well. He is located in the Stafford area.
MKIInut is offline   Reply With Quote
Old January 14th, 2019, 09:15   #4
mattboyd
I've PM'ed and emailed him, several days ago. Based on what I've seen on here about him, that's exactly what I want to do, but I need to be able to contact him so if anyone can help me contact him that would be much much much appreciated.
My goal is to get this done before 300k but I'm at 297,500 now and driving it every day....
Old January 14th, 2019, 18:07   #5
Will Halsey
I know it's a far drive for you, but there is a company located in Reading PA that specializes in diesels. I had them do a dpf delete on my mk6 golf and they do excellent work. If you're willing to make the drive, it would be worth it. The shop name is Dirty Diesels and their phone number is (267)-935-9755
Will Halsey is offline   Reply With Quote
Old January 16th, 2019, 15:32   #6
1854sailor
Resident Curmudgeon
1854sailor's Avatar
I don't know if I'd be advertising for a company that does deletes, which are Federal crimes. The EPA has fined folks like that hundreds of thousands of dollars...
Old February 3rd, 2019, 18:29   #7
Lakenum09
TDI(s): None yet
I am looking for a good machine shop in the Richmond, VA area. I need my PD head rebuilt.
Lakenum09 is offline   Reply With Quote
Old February 7th, 2019, 07:51   #8
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Contact Richard at coolairvw@aol.com. You will have to ship the head to Kansas City, but it will be done right.
Old February 7th, 2019, 14:03   #9
Ker-Pow
Check out Cuz's TDI Werks in Stafford.
Allen Bristow is the owner. He works on my 05 Jetta Wagon. He's reasonable and does great work IMO.
Ker-Pow is offline   Reply With Quote
Old February 9th, 2019, 20:04   #10
packarman2000
TDI(s): 5
i have been working on BEW tdi's for years now. built a few and done what you need many times. that work is very easy for me to do if interested. i have a shop that i do side work in when i am north in my normal job. i live in north carolina though in fort bragg now. if willing to drive you can call me at 305-788-8033 andy. its not that far of a drive being that i have driven your way several times.
packarman2000 is offline   Reply With Quote
Looking for TDI Mechanic in Richmond, VA Y2KGolfTDI TDI 101 6 June 2nd, 2018 18:18
TDI Mechanic in BC? (Richmond/Delta/South Van) tmb05tdi West Coast Canada/USA 5 May 7th, 2008 13:58
Good TDI Mechanic in Richmond, VA? magoali TDI 101 6 August 21st, 2007 06:58
TDI mechanic Richmond VA area? StephF TDI 101 4 April 26th, 2007 21:22
Reputable TDI mechanic in Richmond, VA Johnstee TDI 101 2 April 26th, 2005 18:08
Page generated in 0.12399 seconds with 12 queries
[Output: 96.45 Kb. compressed to 81.88 Kb. by saving 14.57 Kb. (15.11%)]
