BEW '04 GOLF TDI BLACK-Manual Trans CENTRAL TEXAS $3800
5 SPEED MANUAL-NEW FACTORY TURBO worth $1500- excellent transmission.
BLACK ON BLACK
FULL FACTORY OPTIONS FOR GL PLUS VW FACTORY ROOF-RACK ( MPG CAN INCREASE IF YOU REMOVE THE RACK)
Premium Alloy wheels
Traction control-ESP
VW Factory radio/CD/cassette
Cruise control
Everything works
TEXT
show contact info for pics and info
A true classic VW diesel. These cars will soon be collectors cars
MECHANICALLY CAR IS 100% VERY RELIABLE. I have never had a problem with this car. I love it but want something bigger.
75% highway miles. This car can go another 200k. its very common for these German Diesel engines to last until 400K
THE GOOD-lots of new parts all original OEM parts used except for AUDI/KERMA TDI upgrades
BRAND NEW TURBO-replaced 10k ago @ 230K
Camshaft replaced @ 150K
Within the last 2 years
AUDI TT/R32-BUSHINGS- car corne
rs like a porsche now
NEW BILSTEIN STRUTS
New Strut mounts
new inner and outer bushings
new inner out tie rod
new oil pan and oil pan seal with magnetic oil plug
NEW VW BATTERY
AT 150K
Fuel pump replaced
injector rocker replaced
water pump replaced
timing belt replaced at around 150K not due for another 10k
Clutch replaced by previous owner
EGR Cooler removed-so it throws the CEL for this but not an issue
Hybrid Cermaic Brakes in front.
New Brake booster
High grade semi-metal brakes in rear
new disc all around- smooth and great stopping power
Nice dark tinted glass. Plus awesome front windshield visor tint blocks Texas sun. You won't even need sunglasses.
I Did remove the rear hatch tint because it was too dark. I did'nt want to get pulled over.
2 OWNER CAR
WELL MAINTAINED- WELL DOCUMENTED HISTORY Maintenance records available
OVER $17,000 in receipts for maintenance. I have the records to prove
tires are ok 1.5 year old tires
TEXT
DOGBONE-KERMA TDI
ONLY USED SYNTHETIC OIL
NEW OIL FILTER, NEW FUEL FILTER
inspected until March 2018
this car is not part of the VW Recall does not have emissions problems
THE BAD-COSMETICALLY NOT PERFECT
BODY PAINT IS NOT PERFECT
rear hatch lock plastic actuator click cracked but was recently fixed by body shop.
Glove box latch broken-recently by my friend easy fix
ROOF Liner SAGGING-easy fix
FRONT DRIVER FENDER DENTED-Easy fix new front fenders are like $100
Hand brake caliper needs fixing- easy fix
TEXT
Please no tire kickers. Great price look at all the work done. CASH only. I know this cars worth I am happy to keep it if it does not sell.
pics available upon request. Please message me if you have more questions
AUSTIN TEXAS -SERIOUS RESPECTFUL POSTs AND QUESTIONS PLEASE.
