dustystdi
2006 tdi jetta NO POWER cam replaced "TDI IS NOW FIXED"
I just bought this Jetta with NO POWER. I just replaced the camshaft, lifters, cam bearings, timing belt, water pump because they were bad. Before and After cam replacement the car idles perfect but when trying to accelerate i have to feather the clutch and hold rpm's around 2500 just to get rolling. RPM's any lower and the jetta will conk out. I have made lots of graphs but i'm not sure really how to read them. It almost acts like it is not getting enough fuel.
I have done fuel test:
(previous owner said he just replaced fuel filter trying to solve problem less then 100 miles ago)
(1) lift pump flow out of filter is about 2L per minute where i believe it should be closer to 3-3.5L.
(2) At idle, the return line out of tandem pump returned a little less then 1L where i believe it should have been between 1.1-1.5L.
(3) With engine off test return line out of tandem pump with 12v on lift pump and measured 42 ml per minute, I thought i read it shouldn't be over 25 ml at the most.
MAF
(1) I have unplugged MAF sensor and it didn't run any different.
(2) I have swapped MAF sensor with a working MAF and no difference.
EGR
(1) I have unplugged EGR and no difference.
Anti shutter valve
(1) Unplugged ASV and no difference.
Also all combinations of ASV, EGR, and MAF being unplugged at same time no difference.
MAF
EGR
Anti shutter valve
