geodug
What is the best procedure to push start a manual trans CR TDI because of a weak or dead battery?
I am guessing that you can pop the clutch while in 2nd or 3rd gear depending on how fast you are pushing. I'm less sure about the electrical needs to do this. Obviously you don't need to worry about enough power for spark plugs and the fuel pump is mechanical.
Is the ECU critical for this method? If it has little or no battery power will it prevent the engine from being started?
On the other hand, the lift pump is electrical but is this not a factor because when the car starts and the alternator is working the lift pump and other electrical systems will fire up?
Finally, what should be the procedure if you have a DSG transmission?
