Old February 10th, 2019, 15:56   #31
KITEWAGON
KITEWAGON's Avatar
Yes, its a missing panel. I think that is a standard feature that every JSW has.
Congrats on the new car.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old February 10th, 2019, 16:14   #32
shoebear
Thanks! Now I just need to track down the part number. Or else watch the local pull & pay for mk6 cars and see if I can nab one that way.
1998 Jetta TDi: Luk clutch, K04/K03 hybrid turbo, balanced Bosio DLC1019 stage1 nozzles, Kerma chip, braided turbo oil feed line, Frost Heater
2003 Jetta TDi wagon: Luk clutch, VNT17. Bought 9/2014, still doing initial repairs.
2005 New Beetle GLS TDi: Kerma "Dog Collar", Frost Heater, Panzer Plate, Evo lift, Koni yellows
shoebear is offline   Reply With Quote
Old February 10th, 2019, 16:28   #33
ksing44
Wow, it looks like there really is such a thing! Based on the pictures, it looks like there should also be a flip-down cover, but I can't find it. I did find your inverter for sale on ebay!
06-10-VW-Jetta-MK5-OEM-AC-OUTLET-SOCKET-PLUG-POWER-INVERTER
2010 Golf TDI - (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP: 11/8/2016 @139,848 miles, The Fix: 9/27/17 @153,289 miles
Flickr slideshow
ksing44 is online now   Reply With Quote
Old February 10th, 2019, 19:54   #34
hause
I've been selling 12-13 Jetta SPW with around 50k for $8995 for a car in good condition
hause is offline   Reply With Quote
Old February 11th, 2019, 06:09   #35
ksing44
There is a flip-down cover! it looks like it came in different colors, depending on the interior.
Black power inverter with cover
Beige power inverter with cover
Flickr slideshow
Old February 11th, 2019, 06:46   #36
shoebear
Thanks! looks like I will need to order the whole unit in order to get the cover. Or do without, or raid the junkyard. I appreciate the research!
Old February 13th, 2019, 11:51   #37
ToBiN
ToBiN's Avatar
shoebear,
Yes, our 2011 JSW had one. I haven't spent any time in the back seat of my 2013 (yet) so I cant say whether it has one.
It looks like Pick and Pull in KC, Missouri has been buying a lot of the VW buybacks. May give them a call to see if they have and will pull that cover for you and ship it. I'm going to call and see if they have some other options that I'm looking for also.
PICK N PULL
KANSAS CITY MO
Phone #: (916) 367-3170
ToBiN is offline   Reply With Quote
Old February 13th, 2019, 21:31   #38
shoebear
PICK N PULL
KANSAS CITY MO
Thanks for the tip! I'll call them tomorrow.
Old February 14th, 2019, 17:02   #39
Treetrimmer
Why would you go to the expense of replacing a pump with one that will void the 4 year/48K mile warranty that's included with all fixed TDIs?
Just to clear something up, there is no 4 year/48k mile warranty "included w all fixed TDIs." You are confusing the warranty provided on emissions system only, not any other part of the car.
A CPO car, (must be purchased from a VW dealer and be below mileage limit), covers fixed TDI cars for 24 months/unlimited miles. None of the cars offered by independent dealers can have a CPO warranty from VW put on them.
Treetrimmer is offline   Reply With Quote
Old February 16th, 2019, 04:50   #40
We are talking about the HPFP, right? That's what I was referring to when I wrote about the 4/48 warranty.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old February 17th, 2019, 12:59   #41
Treetrimmer
Right. There is no 4-year warranty on the HPFP "included with all fixed TDIs." There may be some separate extended warranty from VW on that part but nothing was added for fixed dieselgate cars.
Old February 17th, 2019, 13:01   #42
bizzle
bizzle's Avatar
The entire fueling system is covered under the dieselgate warranty.
It's not just the emissions system. It's everything that can be impacted by the emissions update, including the long block itself. The transmission is not covered.
bizzle is offline   Reply With Quote
Old February 22nd, 2019, 21:32   #43
shoebear
I called VW America, and they said the car carries the TDi Warranty Extension until 11/4/2023 or 174,579 miles. As bizzle said, it covers everything in the car that's fuel related, including the fuel pump -- I asked specifically about that.
Old February 23rd, 2019, 09:41   #44
CDKJudoka
The is directly from VW in regards to the extended Emissions Warranty.
Parts Covered Under Extended Warranty
 The entire exhaust gas after treatment system, including the Diesel
Oxidation Catalytic converter (DOC), the NOx Reduction Catalytic
Converter, the Diesel Particulate Filter (DPF), the exhaust flap, and
all sensors and actuators;
 The entire fuel system, including fuel pumps, high pressure fuel rail,
fuel injectors, vibration damper, pressure control valve, and all
 The EGR system, including EGR valves, EGR cooler, EGR filter, EGR
temperature sensor, all related hoses and pipes, and all sensors
and actuators;
 The air intake pipe and charge air cooler, charge air temperature
sensor and air mass sensor (HFM);
 The turbocharger, including the turbocharger damper;
 The glow plug;
 The On-Board Diagnostic (OBD) system, any malfunctions detected
by the On-Board Diagnostic (OBD) system other than those related
to the transmission
Additionally, the engine long block warranty shall cover the engine
sub-assembly that consists of the assembled block, crankshaft, cylinder
head, camshaft, and valve train.
The extended emissions warranty includes parts, labor, and applicable
taxes. If the warranty service is scheduled to take longer than three
hours VW must provide a loaner vehicle. The extended emissions
warranty shall not void or supersede any existing warranty. Conflicts
concerning the warranty are to be resolved in favor of the consumer.
CDKJudoka is offline   Reply With Quote
Old February 24th, 2019, 16:58   #45
KeyTDI
I researched and concur what CDK says above.
HPFP is covered, and much more.
The cover over the 110v outlet is held in place by a spring loaded ball each side... mine falls off all the time... check under your front seats... youd be surprised what I found under mine... not all of it was "Nice" surprises...
I'm a stick shift guy... and I am really liking the DSG...
KeyTDI is offline   Reply With Quote
SportWagen purchase bioburner VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 35 May 22nd, 2016 23:16
Need advice on purchase of used 2013 TDI Jetta Dobe General VW Discussion 3 January 15th, 2016 10:30
'11 Sportwagen, new purchase! mgibby363 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 8 August 27th, 2014 07:41
Contemplating a 2010 sportwagen purchase - any advice? Bredto VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 52 May 2nd, 2013 08:05
Looking to purchase Jetta TDI Sportwagen mcracer516 TDI 101 11 June 22nd, 2012 17:31
Page generated in 0.18881 seconds with 13 queries
[Output: 131.71 Kb. compressed to 110.85 Kb. by saving 20.87 Kb. (15.84%)]
