Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 9th, 2019, 17:24   #1
Alcohol
Fuel Economy: 48 to 52 on interstate
Default Maybe a bad battery?
I have a '13 Jetta tdi,,,today it appeared to have a dead battery It started but quickly died,,,then it would not turn over,,I put jumper box on it and it turned over like a gas motor that was flooded,,but it started and I drove it about a mile and seemed fine,,the battery is less than 9 months old,,original VW battry was installed,,I have another issue that I have not noticed before also,,when it is in park and you depredd gas pedal all it will do is 2800 rpm,,but when you get it out on road it is fine,,,is this normal? I have put power service fuel treatment in it for cold weather here.
Alcohol is offline   Reply With Quote
Old February 10th, 2019, 10:33   #2
Matt927
Matt927's Avatar
TDI(s): several
Intercooler icing?
Normal RPM limitation in PARK.
Matt927 is offline   Reply With Quote
Old February 10th, 2019, 12:04   #3
Alcohol
I went out this morning and she fired right up,,as far as intercooler icing,,surely not as this was first time to start that day,,still not sure about the rpm not going above 2800 rpm until I GET IT ON THE ROAD??,, Then about yesterday,,,maybe it would not turn over because of cylinder hydro lock,hence the motor acting like a gas motor that was flooded. Almost afraid to go anywhere,,LOL
Old February 10th, 2019, 16:28   #4
Alcohol
More trouble,,,,drove it to town and back now it acts like it is a limp mode and exhaust smells like a kerosene turbo heater,,no power either
Old February 10th, 2019, 20:44   #5
Alcohol
After reading the thread about inter cooler icing,I believe that is my issue
Old February 12th, 2019, 05:37   #6
06bluebeetletdi
Sounds like my 2013 beetle when the intercooler iced up.
06bluebeetletdi is offline   Reply With Quote
Old February 12th, 2019, 20:04   #7
Alcohol
Thats exactly what I had happen,,,dealer installed kit today to supposedly fix it,,,no charge,,thanks guys..
Bad Mileage until unplugging battery, after 1 tank, bad again IDoSeaDoo VW MKIV-A4 TDIs (VE and PD) 45 December 23rd, 2013 09:07
Bad Battery TDI Frankie VW Passat Family (NMS and B7) TDIs (2012+) 7 May 18th, 2013 05:50
Bad battery already? paul_arc VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 21 April 19th, 2013 21:16
Bad cell in battery debecker13 TDI 101 3 October 26th, 2005 05:50
Bad Battery hlcptrdave VW MKIV-A4 TDIs (VE and PD) 12 January 14th, 2001 21:00
Page generated in 0.11784 seconds with 13 queries
[Output: 76.38 Kb. compressed to 66.34 Kb. by saving 10.04 Kb. (13.15%)]
