01 Golf TDI automatic
I did all of the checks according to the Glow Plug 101 Ver 2.0 and came up with one bad(resistance wise) glow plug. Replaced it and no change. Unplugged the ECT and it stayed on longer, but has no voltage on any of the four connections for the glow plugs. It has the two wire harness. According to the GP101 it is the relay that is bad. I took apart that #180 relay in position 10 and left the case off of it. It would not cut on during initial key on with ECT plugged in but would lock in while cranking and stay locked in while it is running. Is this right for this relay? Is this the right relay to check?
