I found myself under the hood this afternoon looking for a manual adjust on these lights too. There seems to be a white manual adjust screw in the back of the housing. The housing itself has arrows indicating adjust "up" and adjust "down."well, after lowering, it seems my headlamps are aimed too low. i find myself hitting the high beams more often than before to gain more visibility.
how can i manually adjust them up a bit?
--ry
do you have the LP option? i'd rather have the ecu do it for me, if it's capable of it.I don't see the need for VCDS.
Yes. I have the LP option In fact, I manually raised the lights last night. There was an improvement without any codes being thrown. Quite simple.do you have the LP option? i'd rather have the ecu do it for me, if it's capable of it.
