Howdy. Accept my apologies because I barely know enough about VW engines to ask this question. But we have what I believe to be a 1995 VW 1.9 AAZ turbo diesel engine out of a Passat that we have installed in a jet boat. We make an adapter plate so the drive shaft is bolted onto the back of the flywheel, and then fabricated a mount for the starter which would normally be bolted onto the bell housing. The problem is that the starter frequently hanging up after the engine starts and it's not very long before we have destroyed the gear teeth on the starter. We have tried but have not been successful correcting the problem with our fabricated starter mount, so we have decided to try an locate a transmission that we can then cut away the bell housing portion so we can more accurately mount the starter. The problem is that we are not sure which cars or years might be suitable matches for our engine. We need to know the various makes and years that will fit this engine and be assured that the starter will align properly with the flywheel. Hopefully there is a number of modes and years that will fit.
Here is a link to a video that shows the engine being installed. Skip to 4:50
https://youtu.be/ef3fKUV9Ka8?t=294
And thanks for your assistance. --Doug
