You are right there is no sport suspension for Canadian TDI's.jnecr said:Do they have a "sport" suspension option in Canada? Or did you put on some lower springs? or is that stock Canada height? Looks about the same as USA Golfs is the only reason I ask and I thought all Canada Golfs were the non-"sport" suspension.
Hmmmmm it doesn't look too SUV-ish with 18" on stock springs ... maybe I won't have to lower mine after all.biby said:You are right there is no sport suspension for Canadian TDI's.
This is on stock springs.
yeah the height is better than what I expected. I was thinking about lowering it but I guess I will keep it stock at least for now.denass said:Hmmmmm it doesn't look too SUV-ish with 18" on stock springs ... maybe I won't have to lower mine after all.
Those rims are pretty sweet for OEMs!!
Biby, thanks very much for the pics. Just this morning I was wondering about putting a set of 225/45ZR17 tires and rims that I have already on my forthcoming 2010 Golf TDI (blue graphite pearl) and saw your post. It was really helpful to see the 18s on your colour and model of car.biby said:You are right there is no sport suspension for Canadian TDI's.
Speaking of which, while I was in a shop recently a mechanic looking at my rims told me not to use the VW recommended air pressure (as found on the door jam). Because there was so much less tire wall he recommended that I inflate them to something close to their maximum pressure to better protect the rim.canux said:Just this morning I was wondering about putting a set of 225/45ZR17 tires and rims that I have already on my forthcoming 2010 Golf TDI (blue graphite pearl) and saw your post.
I personally do not think there should be any worry about damaging the rims, as long as the tires are inflated with any normal driving pressure.canux said:Speaking of which, while I was in a shop recently a mechanic looking at my rims told me not to use the VW recommended air pressure (as found on the door jam). Because there was so much less tire wall he recommended that I inflate them to something close to their maximum pressure to better protect the rim.
Has anyone else heard this? It seems to make a certain amount of sense to me but I worry about over-inflating the tire.
From online sources these rims weigh 25lbs each. I'm not too sure how much do the stock 16"s weigh tho. However to answer your question I believe these weigh more than the stock 16", just I don't know by how much.denass said:biby a few questions:
1. Do you know if these weigh more than stock 16"?
2. How's the ride/drive on 18" vs stock?
the REAL issue with over-inflating tires is stopping distance is increased...THUS increasing the chances of an accident. When tires are over-inflated or inflated to the max, you have less tread in contact with the roadway surface.GetMore said:If you inflate the tires to the max pressure on the sidewall you will NOT do any damage. You may possibly wear the tires more in the center than on the edges, but that's it.
biby said:From online sources these rims weigh 25lbs each. I'm not too sure how much do the stock 16"s weigh tho. However to answer your question I believe these weigh more than the stock 16", just I don't know by how much.
18" with summer tires are more stiff, thus you feel the uneven road more. And it gives much better grip than the stock Hankooks. I still don't know what to do with them, not sure if those tire shops would accept trade in for snow tires.
