Have a 04 bew Jetta that we have been working on. We could not get it to start without priming fuel to the tandem pump. Replaced the lift pump as it had quit working. Now this car starts perfect cold, but won’t start hot hardly at all. It just cranks and cranks and cranks then it will eventually start. Normally with a blip of the throttle while cranking and it’ll start. Do we have a tandem pump failing? I’m gonna hook up vcds but last I looked there were no codes. This is the 2nd bew car I have had do this.
