flyanddive
With $4467.what does that mean, they will pay difference in what you owe and the buyback?
so I owe $20K and my buyback is $24,467
Where would I end up?
Lower mileage cars have a positive mileage adjustment. Higher mileage cars have a negative mileage adjustment. Seems pretty straightforward to me.OK, now I'm officially confused. The amount calculated for mileage adjustment, in our case from what I can figure out is $4890....
does that get ADDED to the KBB amount, or SUBTRACTED?
If the later, it's time to lawyer-up (which, we hear, VW has to pay 100% of lawyers court costs)
so which is it?
With $4467.
As for high mileage before the fix, there is also a warranty for 4 years/48k miles after the fix.
You would pocket $4,467 after your note is paid by VW.what does that mean, they will pay difference in what you owe and the buyback?
No, Canadian info may be released July 29 per your link.Those tables are for the US Miles. You're in KMs.
Canadian Info is to come out tomorrow per: https://www.vwemissionsinfo.ca/news/tdi-update-u-s-court-filings-regarding-u-s-2-0l-tdi-vehicles/
cause gen 2 cars aren't the same as gen 1 . Theres a reason there are three gens.I highly doubt there will be a fix for the gen 1 and 2 cars. The Gen 3 has the ability to be fixed because that engine was designed to take on a treatment system.
I think it is like this:The part I am confused on is the $2,986.73. Does it go like this?
Buyback + modification +/- mileage adjustment =$xxxx + $2,986.73.
http://www.cand.uscourts.gov/crb/vwmdl/proposed-settlement
https://www.ftc.gov/sites/default/files/pdf/att._1a_-_buyback_modification_table.pdf
https://www.ftc.gov/sites/default/files/pdf/att._2a_-_golf_mileage_table.pdf
I believe the 20% +$2986.73 is included in the $15857 figure.If I'm doing my math right our 2011 books 17057 in my region plus 540 for the sunroof. We have 98k miles, but subtract 8k puts us at 90 for - 1740 for a value of 15857, on top of that 20 percent plus 2986.73 gives us roughly 22k.
I expect the additional sensor requirements for the Gen 3 mods is what is referred to in the reference to partial (2/3+1/3) payments.
buyback offer = buyback (column 1) + 5,100 +/- buyback mileage adj.
modification offer = modification (column 2) + 5,100 +/- mod mileage adj.
That could be intentional, if you think about it. They want to get the high mileage cars off the road sooner since they are producing more total pollution, so there is an incentive to act now. If you never drive the car the pollution impact is less, so it's better to wait....
In any event, because the mileage adjustment simply assumes 1042 miles/month, rather than counting actual miles, high-mileage drivers get penalized for waiting because the "adjusted mileage" for September 2015 will increase over time.
I'm not certain about that. I think you pick column 1 or 2, +/- mileage, and call it a day....
Further Adjustment
(applies to both Buyback and Modification)
If the Modification amount from (5) above is less than $5,100:
a. Subtract the Modification amount from (5) from $5,100.
b. For Buyback: Add the result from (a) to the number from (5) above.
This is your Mileage‐Adjusted Buyback Amount.
c. For Modification: Add the result from (a) to the number from (5) above.
This is your Mileage‐Adjusted Modification Amount.
I read it as either/or. If it's a buyback figure Buyback price +/- Buyback mileage adjustment. If it's a mod, it's mod price +/- mod mileage adjustment.The part I am confused on is the $2,986.73. Does it go like this?
Where do you get the extra $5,100 from? I see it as just option +/- matching mileage adjustment.I think it is like this:
This is at the bottom of the mileage adjustment document:Where do you get the extra $5,100 from? I see it as just option +/- matching mileage adjustment.
Further Adjustment
YOu pocket 6,667 with fix IF a fix is available and take the risk of $20k downside on the asset you still own as opposed to 4467 + 0 risk for buyout.So if I did my math right I have a 2014 Jetta with power seat, Fender, Aluminum/alloy wheels, power sunroof and I am in the southeast
doing the mileage deduction my buyback would be
$24,647
and the fix would be $6,667
I currently own right at $20k on the car
So I would pocket $4,467 with buyback and $6,667 with fix
for me that is not enough money for the buyback
