Old July 15th, 2006, 10:54   #1
bshieldsKC
Fuel Economy: 40-48mpg
Default I'm an idiot. Help
I am in the process of changing my oil, and as I'm under the car I can't get the oil plug off. I continue to second guess myself on which way I need to be turning it to get it off. Also, I'm not sure I have the exact size or bit on the wrench. I can't believe I'm asking these two question on here. Someone put me out of my mysery please. Thanks
B. Shields
bshieldsKC is offline   Reply With Quote
Old July 15th, 2006, 11:01   #2
whitedog
Did you remove the plastic cover underneath? Are you sure you are pulling the engine drainplug and not the transmission drainplug? The Engine drainplug requires removal of the plastic cover underneath and is located towards the side of the car that the fuel filler is on. I don't recall what size it is though, so I'm not much help at all, am I?
I think I'll go back to my yardwork now...
Old July 15th, 2006, 11:08   #3
wmahaffey
TDI(s): 2006 Jetta
I do not know the size of the plug. I have not changed my oil yet. A easy way to remember tight and loose for right hand threads, most things are right hand threads.
"Righty tighty, Lefty Loosey".
Looking at the head of the bolt or nut, clockwise tightens the bolt/nut, counter clockwise (anti-clockwise) loosens the bolt/nut. Please do not hdsitage to ask any question. The only stupid question is one that is not asked.
Have a wonderful day,
Bill
Bill
'06 Jetta TDI, DSG White Pkg 2 - Mine.
'06/'07 Jetta TDI, DSG Blue Special Edition - Peggy's
wmahaffey is offline   Reply With Quote
Old July 15th, 2006, 11:08   #4
Birdman
Fuel Economy: 55 summer 50 winter
It is located on the back of the engine Pan and you turn it counter-clockwise to remove.
Birdman is offline   Reply With Quote
Old July 15th, 2006, 11:11   #5
car54
theGAME
TDI(s): 2002 Jetta
the engine drainplug requires a 19mm wrench.
car54 is offline   Reply With Quote
Old July 15th, 2006, 11:14   #6
whitedog
Sheesh... finally someone that actualy can help.
Old July 15th, 2006, 12:11   #7
bshieldsKC
Default Thank you
Thanks everyone, I was turning it the right way, and even afte I went and purchased the 19mm, it took a good couple pushes to get it to budge. Thanks
B. Shields
Old July 15th, 2006, 14:23   #8
Smokerr
Fuel Economy: 43.5/32/28
Crisis over
2005 Passat TDI Wagon
Smokerr is offline   Reply With Quote
Old July 15th, 2006, 16:07   #9
compu_85
Gadget Guy
compu_85's Avatar
Just don't over tighten it putting it back in
-Jason
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old July 15th, 2006, 20:44   #10
wny_pat
Fuel Economy: 48 mpg
Ah, the benefits of a top drain! But it's still good to get underneath and look around.
'02 Jetta TDI GLS. Bosio Sprint 520. Hella E-Codes. HiddenHitch and rear suspension air bags. Evolution Skid Plate.
wny_pat is offline   Reply With Quote
Page generated in 0.14076 seconds with 10 queries
[Output: 91.54 Kb. compressed to 77.15 Kb. by saving 14.38 Kb. (15.71%)]
