Tjr2550
I bought my current 2002 tdi golf about three weeks ago, it has about 290k km on it, the car was modified with a few things when I bought it. It has a G60/VR6 pressure plate flywheel combo, stage 3 malone tune (with EGR and immo delete on the tune)
Anyways, my issue is. I was driving the car home the other day, and was slowing down to go over a speedbump the engine started sounding a lot louder all of the sudden, so I shut the engine off because I knew that something was wrong; and when I tried to start it again, it just turned and turned but wouldn't kick at all.
So after having the car towed home I tried to do a bit of troubleshooting, couldn't find anything other than when i pulled an injector out of the block and tried to turn it over the injector didn't spray any fuel. I took the injector pump out and took it to NW fuel injection and had it tested professionally, the results of the test came back great, the guy there said hes been working on VW pumps for decades and hes never seen one in such good condition with the amount of mileage that the pump has on it.
The pump is back in the car now and still acting the same way, so there must be something telling the injector pump not to put out fuel
Other things I've tried:
-Changed 109 relay (tried three different ones)
-Changed 100 relay (tried three different #100's aswell)
-Hooked it up to the vag-com, only code that came up was (01177 - Engine control unit unauthorized) Which I wouldn't know what to change to help that code
Anyways I'm really confused with all of this and if somebody could help give me ideas or things to try that I haven't gone over already would be greatly appreciated!
