Old June 10th, 2018, 09:28   #1
DI fan
Fuel Economy: 42 city(wife) 44 city(me) 48 highway. Best 52
Default New tune new MAP sensor 16490 code.
I just upgraded my injectors set the I/Q to 5 via hammer mod, got my tune upgraded from stg2 to stg4 And installed a new 3 bar MAP. Im now getting 16490 codes. It won't produce any boost with the 3 bar map and won't rev over 2500.
If I pug in my old (stock) 2.5 bar map (outside of the intercooler)I get no codes. If plug in the 3 bar map when not mounted in the intercooler I still get the code. I have not tried to install 2.5 map to if it will produce boost.
Is there a measuring block in VAG COM to look what the map voltage is?
I did the n75 test and the actuator arm on the turbo moves about 3/4" of an inch.
I'm assuming one of 2 things. I've got a bad (new) 3 bar MAP or the tuner forgot to set the tune for a 3 bar map.
DI fan is offline   Reply With Quote
Old June 10th, 2018, 11:39   #2
Nevada_TDI
Actually, the first thing to do is to plug the 2.5bar sensor back into the manifold and go for a test drive to see if you get any more codes and go from there. I hate to ask, but where did you get the new MAP sensor from? If you get the implausible signal error as soon as plug the sensor in w/o the engine running, then it is likely the sensor. BUT, I suggest you reinstall the 2.5 map sensor and run logs in Group 11 to check the actual vs requested boost as a reference point from which to work from.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old June 10th, 2018, 13:04   #3
DI fan
The sensor is a Bosch unit from one of the forms reputable vendors. She I first started it up I got the alarm code. I noticed that it wasn’t completely plug in. It plug it in fully butbstill got the code. Is it possible I fryed the new map? I’ll do test logs later 2nite and see how they look. Does anyone know how much they are at the stealership?
Old June 11th, 2018, 11:13   #4
Hasenwerk
Hasenwerk's Avatar
MAP sensors are electricaly all the same:
G71/G72 - Manifold Absolute Pressure (MAP) Sensor
1 BR/BL Engine Control Unit ( Ground )
2 GY/GN Engine Control Unit ( Temperature output, Variable Resistance )
3 LI/R Engine Control Unit ( 5V input from ECU )
4 Y/BK Engine Control Unit ( Pressure output, 0.5 to 4.5V )
Here's some "only had one coffee" math:
More or less (as they aren't 100% linear) 500mV is 0 mbar and 4500mV is 3000mbar on a 3 bar MAP sensor. 3000 input units to 4000 output units with a base of 0.5V works out to: 500 + 1.333 x input mbar = output millivolt.
That means with the engine not running, and key on you should have about:
500 + 1.333 x 1000 = 1833 millivolt or 1.8V
At 25 PSI boost (1700mbar over ambient):
500 + 1.333 x 2700 = 4099 millivolts or 4.1V
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old June 11th, 2018, 18:39   #5
Nevada_TDI
I don't know if any of the "bad" 3 bar MAP sensors are still around: some time back there were some that were that the reputable vendors sold. How do I know, I had purchased one.
First thing look at the holes in the MAP sensor there is an aluminum insert where the screws go through. If the pressed in "ring" has a slot in it, it should be the genuine article if there is no slot, then it is a knock off. Even though MAP sensors almost never fail, they do fail and sometimes come out of the box bad.
When you plug the 3 bar sensor into the harness clip is it rock solidly connected or will it slide apart without using the release lever?
_______________
Old June 11th, 2018, 21:06   #6
DI fan
thanks for the reply's.
Nevada I just found an old post you had where you talked about the bad sensors. I did buy this one about a year or two ago and its been sitting on the shelf waiting until I finally got my upgrades for it. it has no slot and takes some work to get it to click in the plug. I noticed that group 10 shows with key on only, baro and actual as exactly the same number. The 2.5 bar sensor shows about a 100mbar difference.
I put the 2.5 bar back in and I get boost. although It seems to be limited to about 19-20 psi on my gage and is drivable. it does show 2601 (max) specified and requested for group 11. I wonder if that is limited by the 2.5bar sensor. I would hope that 3 the bar will allow it to go higher. I did get a stg 4 25 psi after all.
Does the 2601 mbar come out to 23psi? I f so I may have a boost leak somewhere or my gage is off. I'm waiting to hear back from my tuner to see what they think about the situation. I'm going to order a new 3 bar sensor tonight anyway and see what happens.
Old June 11th, 2018, 21:14   #7
DI fan
Hasenwerk, do you know if there is measuring block in VAG-com that you can see the actual voltage or do just have to do the math and use group11 to compare to?
either way I'm going to compare your numbers once I get a new 3 bar sensor.
Old June 11th, 2018, 22:12   #8
Nevada_TDI
DI Fan stop wasting your time. If it has no slot it is junk. Get the replacement installed and all should be well from that point forward.
Here is your answer: 2601 is 23.22 PSI
(Wow, somebody did read my old posts, LOL)
_______________
Old June 12th, 2018, 01:32   #9
martin33100
TDI(s): VW T5 2.5
Isn't 2601 the original scaled limiter in the ECU?, I have a VW T5 2.5PD and they have a 3bar MAP sensor as standard but when you do data logs they stop reading at 2601 mbar even though it's a 3000 mbar sensor.
Tuners over here either re-do the limiter so they actually read 3000 mbar or they just fit and scale for a 4 bar MAP sensor.
martin33100 is online now   Reply With Quote
Old June 12th, 2018, 07:49   #10
DI fan
I got about 23psi with my math too. I hope the 3 bar sensor will make things all good. It will be here tomorrow. Would the ecu somehow get limited to 2601 due to running the 2.5 bar map? We will see what happens.
I will say, even running the 2.5 bar map stg4 with 1019s. Is great to drive.
Should I be getting more smoke by only running 2.5map? Because there is only lite haze at WOT like my last tune. I wonder if more measured boost will somehow bring more fuel. I’ll have to look at the fueling after I install the new 3 bar.
Old June 12th, 2018, 11:21   #11
Nevada_TDI
Is the tune MAF based, or MAP based, or did you ask?
_______________
Old June 12th, 2018, 12:38   #12
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
Running the 2.5 bar sensor in a 3 bar tune will end up with you getting less boost.
Basically a 2.5 bar of pressure it will be giving out 5v's. But the ecu thinks 5v's is 3 bar. So the ecu will be controlling boost down - by a factor of around 1.3 so that should get you to your 25psi.
The 2601 just shows the tuner is a bit lazy and didn't bother doing the software updates to you can read correctly in vcds.
m1ketdi is offline   Reply With Quote
Old June 12th, 2018, 12:57   #13
Hasenwerk
Hasenwerk's Avatar
I don't think VCDS shows voltage. I would use a multimeter on the #4 wire.
David Marshall
Old June 12th, 2018, 14:18   #14
Nevada_TDI
Here is a different math version of boost using a 2.5 vs. a 3.0 bar Map sensor. If your tune does not throw an immediate error--some do not--putting a 3 bar MAP sensor on a 2.5 bar tune your boost will increase by 20%. Why is this? Because 0.5 is 20% of 2.5 so a 3 bar MAP sensor will "scale" about 20% more boost. The 1.3 factor mentioned above might be correct when going the other way from using a 2.5 on a 3 bar MAP tune.
_______________
Old June 13th, 2018, 10:59   #15
m1ketdi
TDI(s): Leon BKD
I'd used 30% as the bottom end of the map sensor is not 0mbar normally it is ~ 500mbar. So 2500-500 = 2000 mbar working range. 500 mbar is therefore 25% of the working range.
However I think I got it wrong last night and used atmospheric pressure 1000mbar instead of 500mbar as the bottom end of the sensor so ended up thinking it was closer to 30%.
Tune for 3 bar map sensor wersuss TDI Power Enhancements 35 October 20th, 2014 12:54
limp mode with 3 bar map - 16490 eddie_1 TDI Power Enhancements 8 April 25th, 2010 13:52
map sensor code sometimes? fordthurston TDI 101 0 February 23rd, 2008 02:00
16490 MAP sensor mystery absolutetraitor VW MKIV-A4 TDIs (VE and PD) 2 November 13th, 2007 17:10
16490 - Barometric / Pressure Sensor Code DLV VW MKIV-A4 TDIs (VE and PD) 8 February 16th, 2005 08:56
Page generated in 0.15008 seconds with 13 queries
[Output: 127.69 Kb. compressed to 106.90 Kb. by saving 20.80 Kb. (16.29%)]
