Vik F
my car started acting funny today, temp wise.
this morning all was fine, car heated up like normal. while on the hwy for 20 mins, my coolant temps jumped to 130 and the coolant temp CEL activated. I pulled over resevour tank was not spilling over, I then released the pressure in the tank, it overflowed, spilled over...then driving again, my in car vents were blow'n cool air.
I sat in my driveway with the car idling and 1500w zero start plugged in to help it keep warm. Guage temp was at 90, but no heat from vents. the radiator fans were BOTH on, I have only ever once seen this happen on the hottest of humid days stuck in traffic with the AC on.
when I remove the cap, it fills up and even spills over again, but its not coming from the return line, it appears to coming from the coolant sytem fill line ( bottom of sphere ). Squeezing the return line, i could feel pressure building, but again, no coolant.
upper rad hose is hot, lower rad hose is cold...squeezing all lines leads me to believe there is coolant in them.
any info / pointers would be great.
thx
thx
