mannytranny
So I've been ironing out all of the little issues with my Sidekick TDI (AHU). She runs GREAT (so much smoother than my MTDI Sidekick) But there are a few issues...
I consistently get a MIL code for faulty glow plug indicator lamp. (Open/Short to ground) I've wired it properly and it works properly, but always throws this dang code! I measured 30 Ohms of resistance across the lamp I'm using, shouldn't that be enough? Otherwise, I can't quite figure out why it claims short to ground since the ECU is the ground.
Has anyone run across this before? Any work around?
TIA!
TIA!
