TDIMeister
Phd of TDIClub Enthusiast, Moderator at Large
Wow I'll love to see the car in person!! Except for the coal rolling (IMHO), congrats on a great build! Awesome fabrication work!
Man those are some purdy welds. Nice job!
Two rear pipes done.
Down pipe done. All 304 SS
Mid pipe. With handmade 3" to double 2.5" split y pipe. Can buy one so i made it
You doin a commom rail on c5 platform. Are u goin standalone. I would love a common rail !!An order of magnitude or so better than the welds I'm currently doing for my Audi, lol.
From what it says in the diagrams, there is an additional relay for the high beams. Do you have access to the diagrams?I have the W8 switch - two positions left to right and two notches to pull out. I have also tried a euroswitch. Still no halogen high beams. I am also wondering if I am missing a relay or have the wrong relay. I know we removed some and switched some as part of the swap...
No prob. Inbox with your email.I have the Bentley book but never had much luck reading them. A page number might help, I can't find the headlight wiring in there for the W8. Or could you send me the diagram? Thanks!
What's become of this?
Machineman, did you end up having to change any ECU pins at all for the BHW connection?
What did you end up having to fabricate (beside what's listed here on your thread already)?
I am looking at a couple of W8s right now, one sedan that's running great with 189,000 miles on it (I drove it, and drove it hard and fast), 1 owner, $2200.
The other is a wagon with 108,000 miles and is making the cam adjuster noise. Could get it for $1500 or less. That cam adjuster noise, though, is fixable. These engines - based on doing a lot of reading about them - aren't the POSs everyone says. Fitzki points out here
that they have two problems. There are more, but there are two known weak points The fixes are here: this first one is kind of amazing
http://www.w8forum.dk/forum_posts.asp?TID=1196&PN=1&title=found-camshaft-adjuster-fix
and the 2nd one is here:
http://www.w8forum.dk/forum_posts.asp?TID=1537&title=diy-thermostat
As I mull this over and read Otty's swap info and your thread here, machineman, (which I don't mean to hijack), others' input would be appreciated.
It's all a bit lunatic, but then....
