sweet!... i seriously considered going SAS on my truck but it'll never be more than a utility 4x4 ... i do have some highsteer arms if you're interested (cheap! )
I'm very interested in any high steer stuff that you have jimbotesweet!... i seriously considered going SAS on my truck but it'll never be more than a utility 4x4 ... i do have some highsteer arms if you're interested (cheap! )
agreed!.... the 4b weighs almost exactly double that of a fully accessorized 1.9, can fracture your teeth with vibrations and send drive through attendees running for cover ...with just a tune and injectors you can nearly match the torque output and eclipse the power of a stock 4B ... the 4b is a sweet swap for larger rigs though, i'd like to see an old kaiser 4b swapped ....Thanks man, 4bt is just too heavy for what I want, and the fuel economy to power ratio just isnt worth it either.
Very true but there is also a lot of free power available with a few simple adjustments in a 4B....with just a tune and injectors you can nearly match the torque output and eclipse the power of a stock 4B ... ....
turn and count!...I do it on every diff and axle I buy...no surprisesWell check gearing on my solid axle tonight and wouldn't you know the guy lied about the gearing...bbbuuutttt had a guy come buy the original toyota hubs from me tonight and he has the exactly same axle with the gears i need, and the one i have right now has the gears he needs so we're gonna do a 1 for 1 tomorrow after I get out of work! So yay me lol
