JaysinSpaceman
OK, confusion time. I've been working on the cooling system, I've got the upper and lower radiator hoses hooked up but I can not wrap my head around the fact that all the diagrams show the return from the radiator going in the bottom of the water pump (WP) through the thermostat. I would think that as soon as the thermostat opened and the water started flowing from the cool/cold radiator the thermostat would immediately close again before the engine had a chance to cool down.
Does the coolant in fact flow out of the head to the radiator and back in the bottom of the WP through the thermostat? And if so how the hell does this work? I know that I have read several places in this forum that this is how it flows but it don't make no kinda sense.
Second question. The heater core is supplied hot water from the back of the head and is returned to the WP near the thermostat, as per the various diagrams I have found. I remember reading somewhere that you do not want to block the outlet from the back of the head, but in Toyotas the heater system has a valve to throttle the hot coolant flow through the heater core and when the heat is turned off the flow to the heater core is effectively blocked off and therefore the flow out of the head is also blocked off. Has this been a problem for anyone that has done this Toyota swap? Does there need to be some sort of bypass made here to allow coolant flow when the heater core valve is shut off?
This whole cooling system seems to be ass backwards to me, what with the thermostat being at the bottom "inlet" of the motor.
Thanx for any advice here,
Jaysin
Jaysin
