Brett San Diego
2002 Jetta wagon, ALH, 310,000 miles. Purchased at 220,000 miles. I don't know if the engine has ever been apart.
warning, Ph.D. dissertation follows. But, I want to give every detail.
It was running way low on power (had been for a many months). MPG was still good, 41-43 mpg typically. I put vacuum on the VNT actuator just before starting the intake change yesterday, and the actuator moved good.
Suspected a clogged intake. So, I was merrily swapping out the intake right up until the point where I decided to go ahead and scrape the carbon out of the intake ports. The intake was heavily caked. The plenum right after the EGR valve was nearly closed. Maybe you could get your pinky in the remaining opening.
Anyway, I decided to follow others' footsteps here and rotate the camshaft until the intake valve was closed then scrape away with various utensils and vacuum and blow the crud out of the port. Cylinders 1 and 3 were already in a good position, so I did those two. Ports looked so much better. Was feeling really good about things. Moved to cylinder 4 and got to work. After a good bit of scraping, it was time to vacuum. When I looked down the port, I realized I forgot to rotate the cam. The valve was at maximum lift. Doh!
So, I thought I'd try to blow any junk out of the cylinder. I jimmied a small diameter stiff plastic tube to the vacuum hose, fed it down into the cylinder and set the vacuum to blow.
It was kinda like Spaceballs...
https://www.youtube.com/watch?v=qgdzo-7HYQI
And, then it goes downhill from here. I moved to #2. Thinking I had rotated the cam properly, I got to work. Vacuumed, and the intake valve looked open still. Well, I was looking at the exhaust valve lobe. Insert many expletives here. Did the same suck to blow thing down in the cylinder.
And, now the real conundrum. I decided to turn the engine over a couple turns to check on things. Was turning the engine by the cam sprocket and hit a hard stop. As I watched the timing belt, it would nearly skip a tooth with forcing. And, then I became worried it may have already skipped a tooth because I kind of felt a tension and release earlier. (I assumed it was hitting TDC compression on one of the cylinders.)
So, I jacked with the tensioner and was able to skip the cam sprocket back one tooth and tried turning again (now at the crank shaft bolt). No go. Still hitting a hard stop. I cannot be 100% certain that the crank sprocket didn't skip a tooth while releasing the tensioner.
This is where I'm at. I need suggestions on how deep I need to go. If the timing is off, what's the best way to rescue it? I need to get back to #1 TDC, but the engine won't turn. Also possible that there's a mass of incompressible carbon in the cylinder. Am I looking at head removal?
Any comments welcome (including snide remarks about how big a dumb ass one can be).
Brett
Brett
