jagster936
Nice!!
You are probably right!Car may outlive you!!
So if the oil is changed it is no longer "stock"? Or tires?Stock means not changing anything in a purist form. Any work could be considered maintenance if it's in a reasonable mileage range. I couldn't comprehend having a vehicle without at least a few mods.
On my 99.5, almost 400 k miles, nothing changed except TB, water pumps, lots of alternators, vac pump and glow plugs. I changed the 5 speed oil last summer, and it "looked" good, perhaps without all the metal I expected from teaching 4 kids how to drive it. The synchros are rather shot, however.Just did fifth timing belt at 480k Now am at 494k ip was rebuilt at 300k. Cam replaced at 300k. Car still runs good and doesnt burn much oil at all. Only thing Ive noticed not sure if its the head or not, but doesn't seem to boost as high as it used to. Running a 17/49vc hybrid and 23lbs boost but for about past year can only seem to boost to 16-17lbs? Anyone else have very high miles on their head and don't boost as high as before? I'm gonna take this to 580k miles.
It's possible. Guess the head has never been off? Have you gone over the c.a.c piping? Vac lines?Im still on factory oil pump and chain at 495k. Has anyone encountered less boost because of worn valves possibly?
It would seem to me if the Intake Valves are worn so bad that the boost would be negatively affected, surely simply starting the engine would also be affected. So, on that rationale, if the engine starts-up okay, I would doubt the Intake Valves are worn. Also, the same logic would apply to the Exhaust Valves. And, if any valve is not sealing properly (due to any reason), it will not take long before it becomes a "burned" valve resulting in a very noticeable misfire when the engine is at idle.Im still on factory oil pump and chain at 495k. Has anyone encountered less boost because of worn valves possibly?
Boost pipes? Yes we have made sure connections are tight. Havent inspected the vac lines too closely because everything seems to work fine? I mean everything seems to work fine only thing I notice is boost wont go above 16 psi whereas before it would hit 23. I do notice soot on the boost pipe where it goes into my pd150 egr valve which means it may have a leak there? I will check all my clamps on the boost pipe.It's possible. Guess the head has never been off? Have you gone over the c.a.c piping? Vac lines?
I'd definitely go over everything with a fine toothed comb.Boost pipes? Yes we have made sure connections are tight. Havent inspected the vac lines too closely because everything seems to work fine? I mean everything seems to work fine only thing I notice is boost wont go above 16 psi whereas before it would hit 23. I do notice soot on the boost pipe where it goes into my pd150 egr valve which means it may have a leak there? I will check all my clamps on the boost pipe.
I had both replaced during the first TB change after 500k miles, and I think that was a good decision. Though it didn't need to be done at the same time as the TB.I'm still on the factory oil pump and chain at 495k. Has anyone encountered less boost because of worn valves possibly?
