Bengoshi2000
About a month ago, I started getting some serpentine belt noise (a wispy almost whistling sound, not a chirp or squeal). Not surprising as I'm guessing there was about 70k miles on it. (Verified by squirting some belt dressing on it between the crank and ac pulleys and the noise disappeared.) All the pulleys were aligned properly. Belt was starting to show splits/cracks.
I replaced the belt, tensioner pulley and the idler pulley (tensioner shock was loose and vibrating). Started her up... still had the noise. In the past I've found new serp belts have to wear in a little bit, so I decided to wait it out.
700 miles later, I'm still getting belt noise... more noticeable than before belt replacement. I tried cleaning off the grooved pulleys with a stiff bristle brush, no dice. Alignment of pulleys is still fine.
Yep, I could just squirt a bunch of belt dressing in there, but that's like putting protmatter in your Genesis Device... short term gain, long term loss.
Have I missed something? Is there some other trick to try?
