2003 TDI Jetta Wagon Rough Idle
dieseldoggy
Indiana
2003 Gold
My wife's 2003 TDI Jetta Wagon has developed a rough idle. Engine shakes way more than my Golf. Not indicating any codes or check engine light. Runs good and turbo kicks like normal but drives me crazy at idle. No leaks at injection pump. Cannot detect any vacuum leaks. Starts quickly. Has had injector cleaner added to each fillup most of it's life. However not lately as the wife does not have a mechanical brain and usually forgets this task. I have run sea foam thru the tank but does not help. Mileage is 201K. Has had good maintenance all it's life. My 2003 Golf idles purrs like a kitten at idle with 251K. Anyone have any ideas? Both of our cars are TDI 5 speed manual transmissions.
miningman
alberta
2003 Golf
Get a code reader and start investigating group 13 etc . Information you have provided is totally inadequate to even make educated guesses.
jokila
Houston, Texas
2003 Jetta GLS, Manual
Most likely based on what you are describing (rough idle. ok above that.) the Injection Quantity of the injection pump is too low. This would indicate overfueling.
Look up how to set the proper IQ. You will need access to VCDS. If it cannot be done through that, then a hammer mod is necessary to perform.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Here in EU PDs appeared in 2002.
Yea, we just ignore you guys. Best we know right up front you're not from North America or we get confused. 3 letter engine codes really help, we're unfamiliar with the various model names.
Franko6
Vendor , w/Business number
Sw Missouri
Jetta, 99, Silver`
Although injectors can give rough idle, it's usually the IQ (injection quantity) that needs to be addressed. For example, if your injectors are perfectly balanced, with block 13 numbers at 0.00mg/str across the board (no, I've never done that, but come real close...), but the IQ can be a 1, when it should be at, who knows, 5.
When injectors get older, they tend to leak. I agree, running something like Power Service makes the nozzle very clean and therefore, able to maintain needle seating. But under the best of circumstances, nozzles age and will emit more fuel as they age. Raising the IQ can compensate(higher number = less fuel) for some of the excess fueling. If you haven't seen it, look up 'hammermod' and yes, you do need to get the VCDS to get it done well, but some might experiment and get it closer.
Jokila has a link to the Kerma sponsored page, but when it comes to the security socket, we are less than enamored with the device. It's expensive and tends to wear out. We make our own out of a 6 pt 7mm 1/4" drive socket. With a die grinder and a small carbide file, cut three of the hex flats, 120 degrees apart, until you can just lightly hammer it onto the security nut.
Although there are some that make a tool that works, there are some that are hard as lead. We ruined one POS with the first use. Since then, we make our own and sell the socket for a whopping $7+ shipping. If you'd rather, make it yourself.
JETaah
mi 48836
I would not discount the idea of a blown out dual mass flywheel if the injector balance looks good.
BobnOH
not-a-mechanic
central Ohio
That's a sound guess as well. I've been told a bad dual mass flywheel will make excessive noise when simply revved high right in the driveway.
