creekfreak
Just did my ventectomy. One thing to be aware of. When removing the retainer clip to get the spring and valve out don't let it fly apart and shoot parts across the garage. You will not find them. I now know.
let 'er fly ! ! ! !creekfreak said:let it fly apart and shoot parts across the garage.
Maybe these pictures will cheer you up?737tdi said:Is this new? I've never heard of this. You have got to be kidding me. You can't read the plz. reads. Good lord it's been there for at least 5 years. That's where I learned it. Read the how to's please. I know they won't because they have already left. I'm upset. AARRRGGGHHH.
737tdi
Yeah, the reserve is at the other end of the tank from the ventNarfBLAST said:...My conclusion: the 7L reserve after the fuel light comes on is not affected by venting.
LOL! EXACTLY!!!tditom said:Yeah, the reserve is at the other end of the tank from the vent
Correct. The light is most likely triggered by a particular Ohm reading in the float rheostat, ie, when the float drops to a particular position. 7L will always occupy the same volume---yes, yes, fuel expands when it heats and contracts when it cools, but Diesel doesn't expand enough to worry about it. This is why you can fill to the brim and drive 50 feet and not worry about fuel leaking out the filler on a hot day.NarfBLAST said:My conclusion: the 7L reserve after the fuel light comes on is not affected by venting.
Best way to get in touch with RocketChip is to go to a GTG where Jeff is attending. Second best is email... he eventually answers all emails, just takes him a few weeks because he is so back logged.mj1053 said:Just finished mine today, the pics were extremely helpful. Next step is either Alligator or RCII and then Sprint 520's. Does anyone have a contact for RCII, I've tried phone and email several times each.
This does not sound ventectomy related, the ventectomy does not open an holes to the atmosphere, it only opens an internal passage that is normally open only when you put the fuel cap on.kbrenny said:I see a small stream of fuel coming out of a small hose that comes out under the rear corner of the car near the fuel fill area.
Could the previous owner already have done the ventectomy?
If that is not the obvious case why would the fuel be coming out under the car and is it something i should worry about?
Just had a look at the Bentley manual and there is nothing connected to that tube. It is just a spillage drain tube. If you are leaking while filling out that hose are you sure you are not spilling slightly?kbrenny said:looked today while I was filling up and it is coming through the hose that is connected just underneath the filler.
__. Good to hear that it works on a Polo. Here in North America (where most of the board members are), the smallest models we have are the Jetta/Golf and New Beetle. The procedures are different for Jetta/Golf versus the NB so it's not surprizing that the Polo is a little different again.bluey said:Just did this on my Polo 9N2.
DON'T!!!!! I've seen several NB release mechanisms upgefuchted by removing the surround.todhog said:I've got a NB and I am trying to do a ventectomy but I can't get the cover off the filler neck. I removed the only torx screw I can find on the bottom left but it stil won't budge. I took the cap off too but that didn't help. What am I missing here?Todd
