What did you do to your MKIV today?
BakoTDI
Bakersfield, CA
Jetta, MK7
I'm a freak when it comes to wheel balance. I've traded in cars in the past when I couldn't get wheels balanced properly. My guru says I can tell when a wheel is 1/2 oz out. Fortunately he's a freak about wheel balance, too., and tolerates me. However, my TDIs hold both balance and alignment really well. Usually when one of my wheels goes out of balance it's because it's bent. I've taken to collecting Avus 1 wheels for the MKIV cars. Cheaper to buy more than have them straightened.
Wondering if it could be a repair that was done to one of my wheels some time ago that messes with it then.
Shop did a small weld on it [emoji848] can’t remember where it ended up
Dh4276
South Carolina
2006 Golf GLS TDI, BEW
Do you guys also have the need to so balancing and alignment as often as my car seems to need it!? Is it possible that hardware is just not of good enough quality? Anything above 60-65 mph I get lots of wheel shake. I know balancing will take care of that but it seems like my car goes out of whack soon after it’s aligned and balanced.
I have only had 2 alignments since I bought the car and that was because I rebuilt the suspension. As for balance issues, normally don’t have issues there either. I’ll get it checked from time to time, but I have the tires and wheels match balanced with road force balances. Makes a big difference.
Actually, of the 6 vw’s I’ve owned and worked on over the past 10 years, the only balance problem I’ve had was when a shop dropped my bare rim and bent it! They wouldn’t even cover the repair and denied having bent it!
Balance and alignment have always been perfect on each one when checked.
Nevada_TDI
Reno, sort of...
2001 Jetta TDI
It wasn't today, actually it was yesterday. My buddy and I did the timing belt kit, and even though we know better, we timed the pump using the dummy hole. Of course she wouldn't start that way. We went through it again and found the problem. Us.
All is well now,and she runs like a top.
BakoTDI
Bakersfield, CA
Jetta, MK7
Haha that happened to me too. I personally did not know about the dummy hole until after the fact! I was so frustrated that I was about to get rid of the car!! But after talking to a friend and doing some research (in the forum of course), I was able to fix the issue and car started right up!
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2002 (swap from 2L gas); 2016 A3 e-tron
Bought these Recaro GLI seats today.
Just have to go to Canada and pick them up now.
Probably paid too much but i feel good about them.
Whoa - where did you get those seats? I'm always looking for nice upgrade parts on CL and other places up here in BC, and totally did not see those.
Nuje
If you're on aftermarket rims, look to the centering rings; I've had bad luck with those providing a truly OEM-level fit.
If you're on OEM rims...your theory of the weld-fix seems like a good place to start.
BakoTDI
Bakersfield, CA
Jetta, MK7
If you're on aftermarket rims, look to the entering rings; I've had bad luck with those providing a truly OEM-level fit.
Yeah I have hub centric rings hoping it would help. Didn’t really see a difference but it’s much easier to install the wheels now.
Wondering if the quality of the parts themselves would give way to wiggle sooner than better brand parts. I have been waiting to install new TT LCA bushings. I also have new strut mounts and bearings to install but I would like to upgrade my struts and springs with an affordable pair of coil overs. But that seems to be in the distance based on my current COVID budget. Anyway, my Jetta’s suspensión had never felt tight. Is there a way to check if maybe there is any damage to frame? After I purchased car, I started noticing some damages to the front of end like the lower valance was gone and the lower portion of the radiator bracket was broken. Not sure how much damage there really was but just can never seem to get long lasting balancing and alignment [emoji17]
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
"any damage to frame? After I purchased car, I started noticing some damages to the front of end like the lower valance was gone and the lower portion of the radiator bracket was broken."
Uh oh,,,,,,,,,,, nothing on the Carfax? You need to find somebody who really
knows these cars to have a good look. Standardly these cars, when right,
stay in alignment. Do all your bushings and check the subframe.
BakoTDI
Bakersfield, CA
Jetta, MK7
No nothing the one time I checked after I purchased it. I suppose nothing new would be reported since then ...
Dh4276
South Carolina
I had the same reaction.
Didn’t even think about them looking like that, and others have not either. They are the 1937 emblem I found and actually thought they looked more tribal. Being VW history though makes more sense the way your thinking.
Thanks for the feedback!
romad
Prescott, AZ
2005 Jetta GLS Wagon "Cranberry"
benmarks
Portland, OR
2004 Jetta GLS Sedan Platinum Gray
I need to re-seat the cover, but just finished adding power-folding, auto-dimming, heated, memory sideview mirrors with puddle lights:
OkiHero
Matoca,Va
04 Golf BEW
Got the old block stripped and out of the car. The new motor is about 85% complete. Torqued everything down to spec still need to get the TB, a/c,alt and ps mounted. Then I should be able to drop her in put the injectors and related components. Also ordered a new turbo feed line for obvious reasons and a complete block off kit for the EGR. Hopefully have her road ready in a week or two.
benmarks
Portland, OR
This is a combination of VW, Audi and Skoda parts. The power-folding mirrors are from a Jetta/Bora. The auto-dimming mirror glass is Audi. The puddle lights are Skoda. It's a fair amount of work and wiring. You need matching window motors and if you want to use the memory feature, you need the memory module that is usually underneath a power-memory seat. For the auto-dimming to work, you'd need to already have the auto-dimming rearview mirror because you tap into that wiring and you need the corresponding relay. You also need the appropriate switch for the door. I did it at the same time as a Climatronic swap, so that made running the wires for this mod much easier.
There isn't a single thread either. There's a big thread here that has all the info for the power-folding mirrors. The auto-dimming glass and puddle lights were from other forums.
Dh4276
South Carolina
Nice job, a little more than I need to get into right now but would be cool to do in the future. Thanks for the info!
KrashDH
Washington
2002 Golf
Installed my front and rear dash cam yesterday (ran the wires) as well as did the "5 brake light mod". Wish I would have known about this sooner, it's always better to be seen.
I also ordered some reverse LED bulbs. The halogen bulbs are garbage. The rear dash cam will be on the back windshield going through 20% tint. I'm not worried about capturing images during the day, but the rear cam has a "reverse" mode where it will kick on when the car is in reverse and you can see behind you. Kinda cool that it pulls double duty. I'm hoping the light output of the LED's I bought will throw enough light behind for the camera to pickup when in reverse through the tint, but we'll see.
I'm also going to play around with diodes so I can use the "fog" lamp as a 5th brake light and a second reverse light, even though it will be going through the red lens. It may help the dash cam out a bit more picking up that low light as well.
I was a little hesitant at first to put another halogen in the fog lamp for fear of overloading the brake circuit wiring but it seems no one has had too many issues. I guess it doesn't matter though, there will be an LED in there when I get them today and the current draw is so little compared to halogen it won't have any effect at all.
carl20320
SW WA
2004 Mk4 Golf GLS TDI 5spd
Finally got an alignment after all of the suspension work (Bilstein TC Sports x4, VR6 front springs, wagon rear springs, bushings all the way around, and a NEUSPEED rear sway bar). Went in yesterday for the alignment but as has been the case with the last couple of these I have done, the tie rods were too long and I had to remove 1/2" so they could set the toe-in.
Used cutting the tie rod ends as an opportunity to install the new fender liners which were in 4 pieces each, along with new mud flaps as I was missing one.
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
Got the gearbox oil changed in the '04. 2+ qts of MT90 and about a cup of Synchromesh to bring it up to level. Shifting is quite smooth, not that it was bad before. The 4th-5th change is where I can notice it the most. Should have done it sooner...:)
cheers,
Douglas
South of Boston
cheers,
Douglas
Sounds over-filled. Should take just 2 liters total.
romad
Prescott, AZ
Well, 2.11337642 US quarts IS "2+ quarts". I wouldn't call that "over-filled would you? :D
However the "cup of Synchromesh" would make it 2.36337642 US quarts which is kinda overfilling.
South of Boston
No, not until you add the cup of Synchromesh does it sound like too much. He writes "and" not "including."
romad
Prescott, AZ
Yes, I then added that additional 8 fl oz which would take it over 2 liters by 236.58824 milliliters.
I've always followed the directions to fill it until the fluid starts to run out the fill port. Oops, that is for my Miata, I forgot I was in the TDI Forum tab, not the Miata Forum tab! :eek:
PakProtector
AnnArbor, MI
It was a bit nose up, and quite thoroughly running out as I crammed in the drain plug. Just as intended. I have been party to Official level setting for an OEM, and the marker the beast has to get to is 150k miles before turning to dust. Emphasis on fuel economy driving the level as low as is possible. There is a bit of anecdotal evidence in that same direction for the big Dodge Cummins gearboxes. Fill to the level plug, remove the shifter from the top side and add another quart if you want them to live as long as the Cummins.
I am quite OK with a slight over fill...:)
cheers,
Douglas
