I copied my post from LCR's thread post 58. Got tired of referring folks to both.
My new grey top white bodied fuel lift pump came in today from BoraParts.com.
I modified it using larger tubing and components than LCR did originally.
I used 7 spring type hose clamps 14-0094 from procycle for their hose.
I used a 5/16 barbed check valve 47245K24 from
www.mcmaster.com
I used a 5/16" barbed tee 5372K614 from the same source.
One link to the hose is on this page:
http://www.procycle.us/main/fuel_hose.htm
I cut the tee back, as did LCR.
As LCR did, I could see no way to make anything but large sweeping curves to avoid crimping the lines.
I mounted my tee directly on top of the pump.
I had earlier modified one using the 1/4" viton that LCR initially recommended, but the viton had failed on one person's pump, and I wanted to try a different material that was physically tougher. The 1/4" tubing is stretched to its limits to get over the pump's components.
The barb on the underside of the assembly top has a 9.25 mm bulge on it.
The barb on the top of the electric pump has a 9 mm maximum OD.
SnowCat has used this polyeurethane for his ALH clear fuel line for 3 years with no problem, and the vendor says it is good for fuel, WVO and BIO. So I thought I would give it a shot. It is also a lot cheaper than Viton.
This pump has a check valve in the return line, so the return line cannot be used as a fuel source, even with high fuel levels. You might also check yours out, Jeff (jsrmonster); I think I see the bulge of a check valve housing on your pump's return line as well. It was built into the top assembly.
Once modified this pump assembly should be even better than the originals. The original only had a tiny orifice to pull fuel through, and it had to overcome a spring loaded valve in order to pull fuel. This one will have much lower resistance to flow in the emergency, pump off, mode.
[/IMG]
[/IMG]
Hose lengths that I use. Any shorter and they tend to crimp. Though this makes loops that stick out pretty far.
14.0inches tee to check valve
6.5 inches CV to sump, crenellated end
19.0 inches, tee to outlet
1.25” pump to tee.
Remember the tee has to be cut back to a single barb.
Some hints and tips.
Check very closely that the clamps, hose and check valve do not fret or rub on any wiring or other part. Remember that the top will be forced down about an inch when it is installed in the tank.
You should be able to blow through the crenellated end that goes into the canister, but not suck through it. This verifies the check valve is inserted the correct way.
Once the tubing is installed on the pump, insert the lower canister into the tank. Leave the elastomeric seal ring out for now. Then tuck the tubing down and in, first one side and then the other. Ensure the tubing springs out and uncrimps itself.
Let the assembly sit in the tank, then plug it in electrically and install the fuel line connections.
1. Cycle the key and ensure at least 50 ml of fuel flows out at the filter connection. (A better test would be to hook up 12 volts to the pump at terminals 1 and 4, to run it continuously and measure the flow rate. It should be over 3 liters per minute. I think I normally see closer to 4 lpm.) This verifies that your normal fuel path is not pinched or impeded.
2. Then with the key off, verify that you can pull 500 ml of fuel from the tank with a mityvac at the filter connection. This verifies that your check valve and suction line are clear, you want to pull much more than the fuel lines could hold, to prove you are pulling it from the tank suction lines.
Remove the electrical and fluid connections. Install the elastomeric seal ring on the tank, ensure it is flush and smooth, both on the outer lip and inside the tank. Then lower the top assembly down into the elastomeric seal ring, push down on the top to set it flush, square up the hard plastic seal ring and turn and drive it until it is tight and in the original orientation.
3. If you wish to test the suction path, then (after running the pump at least once for a minute) pull fuse 28 and verify your engine will start and run. Then you know the mod is installed right, and you know your car does not have air inleakage that would prevent the mod from being effective.
