287whp 2.0 TDI Jetta and still climbing...
andy2
Bowmanville,Ontario,Canada
13 Jetta,94 Golf drag car 585bhp,Samurai buggy BHW 300bhp,97 Ram cummins
defintiely looks like a good/proven idea.Let's see some common rail compound/staged power ?
Rub87
Belgium
Ibiza '99 90HP
for 400hp daily driven TDI there are not too many wheels I would go for, and the garrett gtx wheel isnt one of them =)
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
What are you thinking Rub, 400hp single turbo or compound?
Rub87
Belgium
Ibiza '99 90HP
both is possible, offcourse, just depends where you want to be below 2500 rpm
ryanp
on a PD below 2500 its nice to have something, on a CR its not as important as there are another 500rpm or so to play with.
We need to talk about the stuff i have coming in shortly!!
Rub87
Belgium
Ibiza '99 90HP
my stuff is in for some time now, but the time is lacking, still havent even measured up the cams of the new engine..
NoJoke
I have a feeling you might fall for the 400hp :D and end up daily driving it.
Just do it....Andy2 did.
TheoSweden
Uppsala, Sweden
A3Q,A4Q, Passat Biturbo TDI
ryanp
no oil catch can, i see no need and always vent back into the engine where i can.
We have an oil cooler but oil rarely gets to 100 degrees even on the hottest day on the airfield for the top speed run!
Rub87
Belgium
Ibiza '99 90HP
If you still havnt bought one I recommend this place: http://www.dli-teknik.se/index.php?section=products&subsection=7&cat=30&s1cat=114&lang=en
I have bought a 600Nm combo for coming project realy nice made flywheel and not to expensive I think. He have stronger ones to if needed.
Edit, for 01E he surely have some special options.
Theo
Kit arrived, flywheel is reallz have and looks to be made will, lot of attention to details. I have the SRE pressure plate and sprung sinter disc.
I will go on friends car with 2260.
m1ketdi
Leam
Leon BKD
I kindv'e see why you might want a catch can after my anti shudder valve died from being filled with oil...... You can still vent back into the engine with a catch can...
Rub87
Belgium
Ibiza '99 90HP
these valves on the 16v fail all the time.. the plastic gear loses its teeth, I don think it has anything to do with oil inside it
m1ketdi
Leam
Leon BKD
My one still had all it's teeth, just failed electrically.... Electrical failure being caused by being full of blow by oil....
