djturbulence
I did not, but I'm going to track down a vagcom in the next couple of days. I did hear back from Jeff and he has requested some vaglogs so hopefully that will clarify the issue.Did you ever do the basic settings 003 test? That specifically tests the EGR, and will test it no matter what Jeff did in the operational portion of the tune. Even on off-road tunes this test still works.
If this test works, then I think you may need to get an updated tune from Jeff. If it does not work, then you have system problems to fix. Either a bad EGR valve, or plugged cooler, perhaps.
thanks
