Old January 11th, 2019, 09:46   #1
jhax
Default Interesting Radio Behavior to Note
Good Morning All,
I just wanted everyone to learn from an experience I had with respect to the stock Premium stereos in our cars. I am unsure if this happens with all of them but it certainly happened with mine (I have the stereo with the CD mono jack from the B3 Passats). Over time as I drove my car daily, I would notice the stereo sound cut out, then come back, then cut out, then come back, etc. The display would remain on but the sound would cut out.
As time progressed I observed the same behavior, with the addition of the entire stereo shutting off and going into "the car is locked" mode (display off flashing red anti theft LED), then it would come back.
I was assuming it was either a bad ground or my ignition switch was going. One day I was driving and noticed that the cutting out and returning suddenly stopped and thought it odd. The next time I drove the car, it was dark out so I naturally turned on my headlights and the radio display light was not on. I have been driving like this for several days now, including a trip to Santa Fe and the radio no longer cuts out.
So perhaps a third reason our stereos cut out, the first being bad ignition switch and the second a bad ground, could be that your display light is going away?
Cheers,
Justin
jhax is offline   Reply With Quote
Old January 11th, 2019, 16:13   #2
ToddA1
Fuel Economy: Dismal
Maybe it could be because the radio is over 2 decades old. Electronics fail. A repair shop may be able to get it 100%, if it’s not the switch and ground.
Both are easy to test.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old January 11th, 2019, 19:04   #3
Mongler98
you USE A RADIO? lol get with the times
Old January 11th, 2019, 21:31   #4
Steve Addy
TDI(s): 97 Mk3
I do too, all the time...
Steve
You didn't poison the coffee, did you? Not anymore than I usually do.
Old January 14th, 2019, 09:47   #5
jhax
Hey, this has an AUX jack, on the other side of that mono cable, why a Microsoft Zune HD is plugged in.
Interesting note during a 20K service today on my 2012 Passat Fastbird VW Passat Family (NMS and B7) TDIs (2012+) 11 January 8th, 2018 12:18
Note to Self lawnarjax VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 July 16th, 2017 01:30
Interesting note received in the mail EricVA VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 December 22nd, 2015 20:08
Note to Self.... MojaveGolf TDI 101 6 April 20th, 2008 19:10
note BawlsyTDI VW MKIV-A4 TDIs (VE and PD) 17 February 26th, 2003 00:08
Page generated in 0.14112 seconds with 13 queries
[Output: 68.17 Kb. compressed to 60.43 Kb. by saving 7.74 Kb. (11.35%)]
