Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old December 15th, 2018, 14:27   #1
Stevie Tease
TDI(s): 97 A4 TDI
Default Sunflower oil modifications clarification.
Guys,
I bought an old 96 Audi A4 tdi a couple of years ago from an old geezer that had a chippy and used to run it on his old sunflower old.
Its had a few mods that I am trying to work out why they have been done and if I need to put some or all back to standard.
As far as I can see the egr (even though its still fitted) has a couple of blanking gaskets, one between it and the inlet and the other on the stainless flexy pipe from the exhaust manifold. The vacuum hose setup is also non-standard it has extra wiring.
Its been no probs for 2 years flying through the mot and emissions but now has an intermittent fault which I think is either fueling or turbo related so am just trying to get my head round why the mods?
Cheers
Stevie Tease is offline   Reply With Quote
Old December 16th, 2018, 05:45   #2
philngrayce
Fuel Economy: 53/43/49 ('02 Jetta 5 sp)
I’m not familiar with the 96 Audi. But many folks WVO or not, disable the EGR in hopes of preventing soot buildup in the intake manifold. As for the vacuum hoses, I’m not aware of any WVO related reasons to do that. Perhaps the EGR is vacuum operated and that is part of the same issue? Or like many older cars, things like vacuum and wiring get modified or “fixed” over the years?
Do cars over there have the OBD diagnostic connections? Do you get any codes?
philngrayce is offline   Reply With Quote
Old December 16th, 2018, 10:43   #3
Stevie Tease
TDI(s): 97 A4 TDI
Cheers for the reply - That's the funny thing, I get no codes and no management light however the light comes on and goes out after about 3 seconds of the car starting which is what you would expect of first ignition.
I think I have sussed the vacuums, as there are 2 N75 valves fitted for some reason but both into the same vacuum config. The EGR is vacuum operated but that bit looks as per the manual so I am just going to remove the blankings and give it a decoke once my new gaskets arrive. From other posts I think my problem is with the turbo wastegate and actuator as the induction system is full of old oil so I have a secondhand turbo on the way also.
Old December 16th, 2018, 11:14   #4
philngrayce
Sounds like a great project. If you haven’t already noticed, some folks on here are incredibly knowledgable about these cars. Post questions in the regular technical section, and you’ll be flooded with good answers.
BTW, aren’t you guys banning diesels sometime in the near future?
motor oil as fuel clarification jwilkins Fuels & Lubricants 24 August 21st, 2008 18:16
Veg oil / sunflower oil uk cars my slow golf Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 3 January 26th, 2008 06:27
TDi Aces EPA Test by running 100% sunflower oil Pseudo_za Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 11 February 8th, 2007 13:28
Sunflower Oil used in Fuel Cells VWannabe Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 2 August 27th, 2004 16:33
OIL CHANGE CLARIFICATION!! RED TDI VW MKIV-A4 TDIs (VE and PD) 2 September 27th, 2002 06:34
Page generated in 0.13133 seconds with 13 queries
[Output: 63.29 Kb. compressed to 56.96 Kb. by saving 6.33 Kb. (10.01%)]
