michael.berta
So I was reading in the FAQ that bigger injectors sometimes do not do as much with a tuning box. My local mechanic (a trusted TDI mechanic) suggests this tuning box with one size bigger injectors to get a 90 HP TDI upto about 150ish HP. It is a 2000 Jetta.
The tuning box increases the injector pulse based on fuel pressure change in the fuel rail. It seems this mod would be OK with bigger injectors since the tuning box has no way of telling that there are bigger injectors in the car.
I'm courious if this combo has worked and what the results were.
Thanks,
Mike
Thanks,
Mike
