BlueOnBlack
Hey folks. My 15 Tdi started randomly going into limp mode. It has only happened at low rpm each time. The code is p0087-fuel rail/system pressure too low. I did change the fuel filter, it was pretty clean and no metal. I removed the fuel metering valve on the hpfp and there was no metal. I do have vcds. Can anyone point me in the right direction to diagnose this? The car is tuned but I have put about 8,000 miles on since tuning with no problems. Thank you
