The front door puddle light harnesses plug into the respective front door control modules. The rear door puddle lights are powered from the BCM directly, pin 52a/4. This splits and runs to connector T28b/9 on the left B pillar and also runs to connector T28c/9 on the right side B pillar. These 2 leads feed each rear door puddle light. Each is grounded to the T28b/21 or T28c/21 pin on the respective sides. There are not rear door control modules per se, although they show in VCDS. It seems to be more of an artifact of prior models. The front door puddle lights are controlled through each door controller, Byte 2, bit 6 for each. I cannot find any reference to the rear door puddle lights in the front door controllers nor in the BCM, although I suspect it may be one of the anonymous bits that are checked with no text shown. The other question is if the SE BCM is compatible with rear door puddle lights. If I recall correctly, both rear door puddle lights come on if either front door opens, whether or not a front door is opened. Perhaps it is easier to simply splice them into the same side front door harnesses - T32b/18 in passenger door and T32a/18 in driver's door controller, but maybe not since you have to take this from the door controller and get it back through the A pillar into the car to go out the B pillar.
