garciapiano
Hi All,
I have decided that the lower CCV delete isn't the best for oil leaks... My valve cover is leaking worse than ever despite my best efforts, and the blocked-off vent on the crank case is probably not helping. I will be replacing all the upper gaskets along with reinstalling the lower CCV vent tube and PCV.
This is my fourth valve cover gasket job I've done and it has leaked every single time. I have a NEW valve cover and all gaskets, but the valve cover leaks in the same place every time, at the cover/head junction behind the middle nut. Is there a proven way to banish these leaks once and for all?
Another forum thread mentioned using hylomar on the mating surfaces... I'm willing to try pretty much anything at this point because I have spent so much on gaskets for this car.
Thankfully, the engine isn't leaking from anywhere else...
