I installed the 5.5 liter washer fluid tank in my car today. It was not a technically challenging job, but it was a 'fussy' job, because it is difficult to get the large tank to fit into the space provided for it. I am convinced now that when the VW factory employees assemble a Golf, they begin with the washer fluid tank, and then build everything else - headlight, fuel filter, wiring harness, engine, etc. around it.
I started by removing the bumper. The bumper needs to be removed to allow you to remove the right headlight assembly. It is not difficult to take the bumper off, instructions are in the photo below. You do
not need to remove the big rub strip, the licence plate or licence plate frame, or the air guides (items 7) from the bumper - all this stuff can remain in place, because the whole bumper comes off as a single unit.
Bumper Removal Instructions
Next thing to come out was the right headlight. That was simple, just 4 screws at the front of the light. Disconnecting the electrical connector was more difficult. It is easiest to do this if you first remove the little 'door' that the connector is attached to, then remove the connector from the door assembly. Then I removed the two bolts that secure the fuel filter to the edge of the front fender. This allowed me to move the filter a little bit, to get access to the stud and nut that holds the top outside corner of the washer fluid tank in place.
Bumper and headlight removed, original 3 liter tank still in place
Once the headlight was out, and the fuel filter was loose, it was pretty easy to remove the original 3 liter tank. I just removed the two nuts that held the tank in place, wiggled the pump and low level sensor out of the holes they fit into, and took the tank out.
I removed the rubber grommets that hold the pump and the low level sensor in the holes provided in the tank. These are re-used on the 5.5 liter tank.
I purchased a plug to close off the hole on the front of the tank where the headlight washer pump would go. This plug, VW P/N 2D0 955 465B, cost me CA$ 0.51 (about ten cents American) at my local VW dealer.
Sealing Plug to close off unused headlight washer pump hole
It is worth mentioning that it is a lot easier to install the sealing plug, and later the grommets for the low level sensor and the windshield washer pump, if you first put a little dish detergent (liquid soap) on the grommets and plugs. Install the windshield washer pump motor and the low level sensor on the new, larger tank before you attempt to put the new tank assembly into the car. You can't easily get access to these components once the tank is in place.
I then
tried to install the larger tank. No go, no matter how much I coaxed and swore at it, it would not fit through the gap. I needed to remove the large plastic air tube that runs from the intercooler to the back of the motor, and to do that, I had to disconnect the two fuel lines that ran across this tube to the fuel filter, and then lift the fuel filter out of the way. Fortunately, all these lines and tubes were just held in place by spring clips. Once I got all this crap out of the way, I was able to fit the new tank in place.
Air tube, fuel lines and fuel filter out of the way, ready to install large tank
Finally, I got the tank installed. Getting it past the 'half-way point' was what was difficult. Once it was in position, it was easy to attach the same two nuts to the same two studs to hold it in place. As you can see, the 5.5 liter tank sticks a long way out into the right hand fender area.
Finally got the big tank in place after 30 minutes of coaxing
All that was left was to hook up the air tube, re-secure the fuel filter mounting bracket, hook up the two fuel lines that went across the air tube, and put the headlight and bumper back in place. Plus remove the inlet filter and cap from the old tank, and put them on the new tank. Total time, not rushing - 3 hours.
If anyone else wants to do this mod, the only part you need to get from Europe is the large tank itself. The plug for the second pump hole you can get locally. No other parts are needed. Because of all the bending and flexing of plastic parts, the job needs to be done in a warm environment.
5.5 Liter tank installed
When the job was all done, I did notice one little problem that I had not anticipated. There is some kind of fluid tank located between the coolant tank and the windshield washer tank. It has a green cap on it, and there are two hoses that come forward out of this tank, pass alongside the inboard side of the washer fluid tank, then bend downwards. When the larger tank is installed, these hoses are displaced about half an inch inboard. I don't think that they will foul against the rotating parts of the motor, but I am concerned that the upper of the two hoses (on my Golf, anyway) does not fit into the moulded slot provided for it on the inboard side of the washer tank. Have a look at the second photo from the bottom, above, and you will see what I mean.
I am going back to Europe later this week, there was a Golf TDI in the showroom of my dealer there last week, if it is still there, I will have another look and see if perhaps different hoses are used when the 5.5 liter tank is installed.
[ February 17, 2002, 22:11: Message edited by: Michael Moore ]
