billmn
- Joined
- Nov 13, 2003
- Location
- Minneapolis MN USA
- TDI
- 2010 JSW stock:Totaled 2000 black Golf gls 315K : retired
Hey guys, I had my turbo fail at highway speed a couple weeks ago. I finally got the new turbo put in tonight.... I double checked everything as I went, but now I started it up and let it run for a minute or two (to make sure the turbo got lubed up prior to actually driving it), the engine sounds normal but I am getting 0 boost and driving around the block I smoked out all my neighbors and the car is now a quart of oil low!!! I will change clothes again go look at it agian to make sure I didnt goof up an oil line or something.
Does anyone have any ideas where I should start? In my thought process if I have an engine that idles and I can drive the car.... then the engine shouldnt be bad.... is it possible the turbo was defective, or did I do something wrong and ruin the turbo?
If the turbo was/is bad that would explain the rapid drop in oil and the lack of boost, but this is a brand new Garrett (not rebuilt) so it doesnt seem likely that the turbo was bad out of the box but I know it can happen.
Bill
Bill
