02BoraTDI
I have a 2002 Jetta TDI with 60k on it. My wife was drivign and pulled to a stop sign and it just stopped running. After checking it out i thought it might be the fuel filter since it would start and rev on its own and immediately shut off. After getting it towed and running Vag on it i came up with the following codes:
17969 Quantity Adjuster (n146) control Deviation
17971 Quantity Adjuster (n146) Lower limit reached
16486 sensor signal too low(g70)
17946 Fuel Shut off Solenoid Valve, open or short to ground (n109)
intermittent
I just recently replaceced the boost sensor with a 3 pin. My mechanic said that the Fuel Shut off Solenoid is losing power, so is this because the solenoid is bad or is there an ECU problem, or am i looking at a pump rebuild. I am hoping the Solenoid problem is causing the Quantity adjuster codes. Might be totally off im not a mechanic.
Any help is appreciated.
intermittent
