kooyajerms
grocery getter
- Joined
- May 5, 2004
- Location
- Pomona, Southern California
- TDI
- 97 B4V (mine), 11 x5 35d (hers) 04 V10 (that one you want), 2014 Q7 (mom's) 74 Shasta 1400
... make that twice a day ... (and depending on where it stopped, it may actually be correct one more time when daylight savings time is coming out of use...)Sheesh. Even a stopped clock is right once a day.
(outdated joke, sorry) HEE-Hee!I've also had unprotected sex and not contracted any diseases.
Unprotected sex for all!
Threads about failures from doing the procedure correctly: Zero, none, zilch Nada........Newbies, do not go to the dealer. They don't know how to work on your car. They are over priced and cut corners. They won't do all the parts necessary for a timing belt. In general they will just mess your car up. There is sticky about "Gurus" look them up and make friends. Driving 4-5 hours to see a guru to have a timing belt done every 100k (or 60k depending) is MUCH cheaper than taking it to the dealer, including fuel and time. That's just the upfront costs. You'll also save $1-5k on a new head or engine when the dealer timing belt breaks.
I don't have time to follow all threads on the forum, if you see something that falls into category send me a PM so I can add it. I'd like to concentrate everything in this first post.
Timing Belts:
another botched timing belt job
Problems after replacing timing belt
What to expect when a Dealer does a Timing Belt Job
Dealer timing belt change
Timing belt mess
98 jetta tdi that "runs away"
Default engine hesitating after timing belt replaced and engine decarbonized (Look at the Parts List)
Default Timing Belt Replacement, Dealer Quote: $1500
Default Dealer Replaced Timing Belt, Now Replacing Engine
Dealer changed timing belt - now no power
Mississauga VW Stealership Boycott
Default help possible dealer issues
Help me prioritize deferred maint. on our used '00 Golf
HELP...
translation...........the crowd has spoken...All I can say is, it is real expensive when you make a mistake.
It will take more time and gives Murphy more opportunities to screw things up. There are a lot of folks that can't get their head around the fact that Spending $100 to save $5 is just bad math.I don't see that it saves much time or trouble.
I would be interested to see before/after timing graphs but not enough to do it twice myself. I don't suppose the OP has VCDS.
Ben, you are too funny...lolI've done 3 timing belts with all the goodies that go with them. I have the tools and VCDS. Now having said that, I have another special tool! I keep Steve Addy on speed PM. Works for me.
Twice a day unless it's military time.Sheesh. Even a stopped clock is right once a day.
