Old February 16th, 2017, 21:01   #61
deecee
Ah ha, do I spy Audi TT shift lever? at least that is what mine looks like.
deecee is offline   Reply With Quote
Old February 17th, 2017, 16:17   #62
G60ING
G60ING's Avatar
Yes I was able to score a TT shifter assembly, I'm not certain if it's really necessary but when I took apart the 02j shifter I grabbed from the jy for the conversion I found the lever was bent and a local gave me a TT shifter for free.
G60ING is offline   Reply With Quote
Old February 18th, 2017, 12:53   #63
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
Fuel Economy: 56 avg.
I have not installed the shifter yet. I was going to disassemble and relubricate the mechanism since it was underwater during one of the floods. Did you buy the Polo parts or cut your body?
So the TT shift has a 10 o'clock offset and a different length maybe? I know the weight has a shorter throw for front-to-back. Anything else?
I have a bunch of these shifter weights now.
Pin style Audi TT or whatever late 02J with 20% shorter throw front-to-back: 8N0 211 051 A
Pin style normal:1J0 711 051 Q
Ball style:1J0 711 051 D
I don't plan to use the Audi TT short shifter weight if someone wants to buy it. I am a lazy shifter. It's the best way to protect your tranny from a hard jerking.
MK3 delete
Houpty GT is offline   Reply With Quote
Old March 28th, 2017, 20:31   #64
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
My differential finally came in. If you want one and have the money, I recommend you buy it and keep it under your bed until you need it. Now that I have this LSD, I can finally do this tranny! Very excited!
MK3 delete
Old March 29th, 2017, 19:12   #65
G60ING
G60ING's Avatar
Congrats👍
Old October 12th, 2017, 14:16   #66
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
The 1st through 3rd gear upgrade is awesome. 1st gear is no longer too low and you shift into second around 15 MPH instead of 10 for casual driving. It took a lot of the burn-out-monster out of the car but I bet it is faster now because more time is spent in first. I put a Peloquin in also so that is also a major factor. 2nd through 3rd are proportionately sized to make for smooth shifting into 4th gear. The gears come from a 1.8T and I believe a VR6 also. I wish there was a nicer upgrade for 4th gear. The one option I saw on Boraparts was expensive and too insignificant of an increase (+7%?) to match well with an upgraded 5th gear.
Does anybody have recommendation for a transmission mount that is stronger? I split another hydraulic mount in half. I do not want to transmit any more vibration so racing mounts are out. Remember it's a daily driver.
MK3 delete
Old October 12th, 2017, 14:32   #67
G60ING
G60ING's Avatar
The G60 Corrado uses a solid rubber mount, that is the next step up from the hydraulic. The great part is that its only $25 shipped or so. The bad part is the installation is something I don't like to do by itself.
http://www.germanautoparts.com/Volks...smission/143/1
Old October 12th, 2017, 22:04   #68
vanbcguy
vanbcguy's Avatar
For what it's worth the G60 mount is definitely a source of vibration frustration in my life. Were the hydraulic mounts you broke VW or another supplier?
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old October 13th, 2017, 07:51   #69
G60ING
G60ING's Avatar
also consider replacing all of the mounts at one time.
Old October 18th, 2017, 20:54   #70
Houpty GT
Houpty GT's Avatar
TDI(s): Corrado
The Chinese mounts broke right away. The top plate just pulls right out. I have been using parts car mounts and those hold up for about a year. I remember the G60 mount giving me vibrations many years ago. I might have to look into modifying the stock mounts if possible.
MK3 delete
Old Yesterday, 10:04   #71
G60ING
G60ING's Avatar
In the VW Corrado world we found mounts would fail when mounts weren't all replaced at the same time.
Boraparts now Cascade German has this set of mounts that I bought a few years back and had great success with.
http://www.cascadegerman.com/product...9262l-set-aft/
http://www.cascadegerman.com/page/1/...vpf-ymm-search
'00 Bora TDI (my new daily driver) deepsilver Jetta/Bora/Vento TDI Picture Gallery 5 August 22nd, 2012 06:53
TDI daily driver Clutch Upgrade pristinemotorworks VW MKIV-A4 TDIs (VE and PD) 4 November 30th, 2011 18:08
Need a Daily Driver... Or Jetta TDI vs. Civic? jdhunt0 TDI 101 8 November 10th, 2010 12:40
TDI best for me for a daily driver? HardHitter TDI 101 50 June 26th, 2009 14:31
Project Corrado TDI matt_harwood TDI Conversions 6 November 24th, 2005 19:38
Page generated in 0.12753 seconds with 12 queries
[Output: 104.25 Kb. compressed to 88.26 Kb. by saving 15.99 Kb. (15.34%)]
