AllenAlic
Anyone located near Nw Indiana, Chicago area that has the ability to reprogram the computers for a manual conversion?
If you are talking for the ECU to be changed to a manual configuration, then typically a tuner like Malone, Kerma, TDTuning will need to do that. I have used TDTuning for all my conversions but they are all good.
If you are talking about just getting the ABS to talk to the ECU after a ECU flash then that is simple soft code programming.
Dealer cannot help on the flash for the auto to manual. They also will not touch the ABS programming as it is not stock. They WILL however flash over the tune you have if you take it to them after you go through Malone or another tuner. Never let them mess with the ECU after you have it flashed.
VCDS won't work, you will need an ECU flashing tool rather than a diagnostic tool. Can also ship the ECU into us directly if you'd prefer, and we do have a fair number of distributors around your area.
I just went to the process. You need a to flash the ECU and reprogram it for a manual transmission. You also need a VCDS once the new software is installe to change the codes from auto to manual and get the the ABS and cruise control working. I used Malone, I rented a FLASHZILLA 2 from them and I already had a VCDS,wagcom. I also added a stage 1 tune at the same time. It was not cheep but I was happy with the outcome. The new tune came via email and was fairly easy to install.
I have the trans from Dutch already, hopefully have the auto out this weekend. Waiting for the rest of the parts from Dutch. Ecu out for flash, VCDS on hand, new rear seal and oil coming today along with the pilot bearing. Going to tackle the wiring if parts don't show instead of waiting around.I installed a FHN transmission with a SBend Stage 3 daily ($$$) clutch and a LUK DMF flywheel. The Malone stage one produces about 30 FT Lb of additional torque and it is noticeable. I am not in the smoking tire business or fogging up the neighborhood with black smoke. My interest is longevity. MPG did improve about 4-5 MPG.
How far along are you in the swap? Not sure if you have purchase a transmission yet I cruised Ebay Deutchlang (I read and speak fluent german) and noticed a GGB trany for sale for about $500 shipped to the US. FHN and GGB are the same.
