Squibals
So I broke my oil pan by sliding into a drainage ditch. It was smashed into the chain/sprocket of the oil pump. When I took the oil pan off the pump looked ok. I'm stupid. Put the new pan on and started the car....... Tempt light came on immediately. My understanding is that to change the chain, tensioner, and pump you have to expose the timing belt. Is there an easier way. How would you guys start from easiest/cheapest??
