brkdrvr
- Joined
- Mar 2, 2013
- Location
- Milton, DE
- TDI
- 2011 JSW TDI 6spd manual 140K, 2012 JSW TDI A/T 50K, 2014 JSW TDI A/T 40K, Ross Tech VCDS-MOBILE
2009 Jetta Sportwagen poor mpg - EPA fix, engine/DSG tuned, new susp, tires & algnmt
Hello, Wondering what mpg others are getting in similar circumstances are getting. The Vehicle in question is a 2009 VW Jetta Sportwagen with DSG transmission. The car has @ 165,000 and is in fairly good condition, it has had the emissions fix. @ 25,000 miles Prior to the fix I replaced timing belt w/kit (timing belt, rollers, water pump, acc belt). About 3,000 miles after the fix turbo died and I replaced, car was getting @ 36mpg hwy. I installed a Kerma tune and thought mileage might have improved (car was not driven much before starting other work) . Recently I replaced all springs, shocks & struts (rear springs were both broken)w/heavy duty 2"lift kit, installed 4 new Goodyear assurance comfort treads, had a 4 wheel alignment done, replaced all 4 rotors and pads and fully flushed brake fluid. While I had the car on jack stands in garage I also installed a DSG tune from Kerma. Upon retuning car to service noticed much improved drivability from transmission esp. from start up and at low speeds. Within a day or so, got glow plug light accompanied with CEL and code 001592 - throttle body actuator implausible signal. I removed TB and cleaned, replaced and cleared code, Mil & code returned (no glow plug lt) and then after a few local short drives Mil went out so I cleared code and let my daughter take car on a 300mi round trip mostly hwy at @65-70 mph. Car only got 36.5 mpg calculated w/actual miles and gallons used. The car rides very nice ( Koni shocks Suplex springs & new tires), tracks straight and is quiet. DSG tune seems good. I just expected mileage closer to 46. is anyone out there running Kerma tune with DSG tune in an 2009 Sportwagen? Any ideas?
