i am looking at this TDI locally...
2003 golf tdi
5 speed
99,000 miles
Turbo Replaced
New Tires
Fuel Filter
Oil Changed with full 5w40 synthetic
Air Cleaner
Injector Nozzles upgraded to Sprint 520's (European Specification 110Hp)
Comes with the timing belt replacement kit...i can probably do this myself...
What the owner says:
"The car has been hit and has a rebuilt title. However, it was a light hit in the driver side B-pillar. I bought the car fixed but replaced both the side airbags because the previous owner did not replace them. The car tracks and brakes straight and the tires have about 10K on them and there is no adverse wear from the accident. None of the suspension was affected."
He said you can tell from the paint lines where it was fixed, but hasn't experienced any problems...but also, he has only put 300 miles on it since buying it...
price is $9800
is it common for the turbo to go that quickly? anything i can expect to go wrong? the price seems good enough that even if i have to drop another 2000 into it, then i will still be much under the going rate of others out there....
what do you all think?
2003 golf tdi
5 speed
99,000 miles
Turbo Replaced
New Tires
Fuel Filter
Air Cleaner
price is $9800
