2014 tdi q7 headlight dip
rbarrs77
westchester ny
2014 Q7
Hi all just bought a 2014 q7 tdi and i notice the driver side healight is dim and purple toned. i did a few times also get a dash notification for headlight dip.
OBD means On Board Diagnostics
DTC means Diagnostic Trouble Code
So this means you need to use a scan tool to "ask" the car's modules, in this case the headlight range control or whatever it is called, what is troubling it.
That car has a $1600 headlamp, it most certainly can tell the controllers what ails it. Although in many cases, the fix means replacement of the assembly, because they do not sell parts inside of them (and you couldn't get them apart to replace anyway).
To clarify, the headlamp list price is about $1250, and it does not come with a ballast, that part is about $350.
I think OBD works, and that is where I would start. But if you want to throw a $350 ballast at it on a guess, you certainly can.
