Old May 8th, 2017, 07:26   #1
Fosco
Talking Run an ALH naturally aspirated ? (+sketchy dump valve fix)
Hey guys, long time lurker here, I'm 25 yo from France, been reading stuff & troubleshooting cars with help of this forum for awhile now.
I often get to work on TDI's (even tho I'm not a mechanic), it's about 10+ cars I often work on which are TDI powered (1Z, AHU, ALH, BKC and even 5cyl AXE engines).
So let's get started with my current subject :
My company owns a worn out VW Caddy TDI from the 2000's with ALH engine.
The car is falling appart from each and every side but lately, the VNT turbo started to get stuck and the ECU went to limp mode ... pretty annoying.
Since we don't give much f*** about it, we're not going to fix it, but instead of throwing it in a junkyard, we went for a temporary crappy fix : add a "non automotive" dump valve before the boost sensor.
So here it comes, we picked up a 7 to 11 bar (100-160 psi) safety valve, replaced the original spring with a softer one laying around and began setting it
0.9bar (stock pressure IIRC), boom it's done
Then comes the piping process, the plumber way :lol:
Fitted in the car
I went for a test run, it whistles so hard, it's so much fun, then goes the boom, hose went off, oil everywhere
We added some retaining springs for the hose not to fly (yet, mostly for fun, we know this wont last), and I went for another, longer testrun and well ...
Success(ish*), the ECU won't go in limp mode. The sensor still shows some pressure peaks, yet the valve blows everything away quite quickly (a bit too hard tho, pressure goes down very fast).
* : Hoses still tend to fly away
It's a lot of fun hearing the (way too) loud whistle over 3k RPM ... now we wait for the turbo to blow (judging by the oil in the hoses, it's coming soon) :lol:
Now here comes the questions about the next step :
We'd like to keep this Caddy beater. It runs once a week to get cardboard & other garbage to recycling center and definitely won't need a turbo for that. We don't want to replace the turbo on this turd, or spend too much time/money working on it ... but at the same time, it would be a bummer to send this thing to the junkyard since the engine / brakes / drivetrains are perfectly fine ...
I had thoughts about going the N/A route on this one, like bring the maf before the inlet manifold, let the turbo blow nowhere (well atleast in some kind of box to retain the oil lol) and boom done.
Problem we had before fixing it with the ghetto dump valve is that limp mode is way too low power, I know this ALH can achieve more power while N/A than in limp mode but I don't know the in and outs of doing this.
My biggest concern being the current turbo ... we don't want to remove it ... but at the same time, it will probably blow and spill oil everywhere ... and we don't want to damage the engine.
Maybe shunt oil feed / return and let it blow ? ()
Anyways thanks for reading all this crap,
Fosco
Fosco is offline   Reply With Quote
Old May 8th, 2017, 09:04   #2
KLXD
How do we know the oil is from the TC and not the crankcase vent?
I would speculate that limp mode is as much power as you'll get with no TC. The ECU is setting the fuel based on no boost.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old May 8th, 2017, 09:11   #3
Good Ol' Boy
VeeDubTDI's Avatar
Here in the States, companies are offering a "stage 0" tune that is designed for turbo-delete. I'd expect something in the neighborhood of 60 hp.
Old May 8th, 2017, 10:08   #4
\/\/0J0
\/\/0J0's Avatar
Fuel Economy: At least 2x that of my TJ
I would say that if you continue running it like that, your chances of having the the turbo puke all of the engine oil into the intake are great. Best case scenario here is that your engine runs away. Worst case is hydrolock and smashed rods.
1. Take the turbo off, cut the vnt housing off and weld a replacement pipe in place to join the manifold to the downpipe.
2a. Replace etdi injection pump with mtdi injection pump and throttle cable.
-or-
2b. Go with stage 0 tune as mentioned above
3. Enjoy having plenty of time to take in the scenery on your drives along with the relaxed lifestyle that life out of the fast lane will bring.
Sent from my mobile look-at device
I miss my TDi
"Those willing to sacrifice Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is offline   Reply With Quote
Old May 9th, 2017, 21:19   #5
need4speed
need4speed's Avatar
Sick build.
And it inspired me to write a poem:
Rock a by turbo in the engine,
When the vanes seize, the boost wont give-in,
When the shaft breaks, the turbo will fail,
and into your valve train, shrapnel will sail.
2003 Jetta 4dr TDI.
G60/VR6 flywheel/clutch. VNT 17 retrofit.
Never. Trust. Dealers.
need4speed is offline   Reply With Quote
Old May 10th, 2017, 00:06   #6
AnotherPerson
TDI(s): 1999 Beetle
I suspect with good injectors it can be more. First hand experience in limp mode on worn and new injectors is night and day.
AnotherPerson is offline   Reply With Quote
Old May 10th, 2017, 05:04   #7
Fosco
Well so far I removed every hoses and before the turbo it's not THAT oily and crankcase vent looks alright. And even tho it wouldn't be an accurate way to know, considering the vast amount of oil in the lines, the engine would probably be dead by now if that was from the vent. 99% sure it's the turbo
Ye I saw something like that existed here aswell, that would be a nice idea once we figured how to do the proper "turbo delete mod", I mean physically.
-or-
Hahaha, that's exactly what's in my mind.
I'm buying the "cut the turbo and weld a tube inside", it would match the degree of f***s given to this beater
I even thought of a sketchier way to mess up things :
- block air intake & cold side while the turbo still fitted in the car (I still have to figure how)
- remove the oil lines, let it blow / clear itself (idk how oil is supplied on this engine/turbo tho)
- profit (It's good to be dreaming nah ?)
Originally Posted by need4speed View Post
Sick build.
Sir, you really made my day.
Old May 23rd, 2017, 08:25   #8
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Everyone loves watching a train wreck.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old May 24th, 2017, 13:55   #9
Nevada_TDI
The oil supply is on the oil filter housing on a banjo bolt. I had to run my car w/o a turbo for a short amount of time so I made a short bolt to thread into the housing , sealing with one copper washer. I left the piping the way it was and she did not have much power, but she did smoke a lot even with the IQ somewhere around 11.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old May 24th, 2017, 14:36   #10
Curious Chris
Fuel Economy: 47/42/38
Or maybe 50 hp. The 1.6 non turbo diesel was 50 hp 80ft torque.
Curious Chris is offline   Reply With Quote
Old May 24th, 2017, 15:26   #11
Andyinchville1
Hi,
How about brazing a band around the copper pipe to help retain the hoses and run the turbo...The reason the hoses are slipping off the copper connecting pipe is because it has no "ridge" to help hold the hose on....I wish I had a pic I could post to illustrate what I mean, maybe somebody else here could help with that).
Hope this helps
Andrew
Andyinchville1 is offline   Reply With Quote
Old May 24th, 2017, 15:40   #12
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Why not correctly diagnose and fix the limp mode cause?? It may not need a new turbo and probably has a stuck actuator or stuck vanes in the VNT mechanism. The vanes in the VNT mechanism can get stuck from soot buildup from poor TDI driving habits or other problems causing lots of soot from running with no boost for long periods. Consult the stickies at the top of the forum section for more information.
Good luck.
Sent from my Nexus 6 using Tapatalk
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old May 26th, 2017, 12:32   #13
Fosco
That's good to know for the oil feed. We'll dig into that later.
So far, the only long term, "easy fix" will probably to swap the car with a 1.9D and get rid of all the issues we're experiencing.
Originally Posted by Andyinchville1 View Post
Hi,
Hope this helps
Andrew
That would've totally helped Andrew thanks but we did bent the edges of the copper tube to act like a retainer or a ridge. In addition we replaced the hose which was a bit too short and the problem got solved.
In addition, the copper tube & the hoses were oily, that's why it failed !
Good luck.
Hey, at first that was what I thought. I went through all of the process of diagnose for this issue.
The result is :
N75 does its job.
Boost pressure sensor reads ok all along the boost magnitude.
ECU "knows(/read) what's going on"
VNT actuator is ok / holds vacuum etc
But yeah, mechanism is stuck when the engine (turbo) is cold, it can't move all the way down or up, I can't remember.
If it was the only issue, we could've fixed it the proper way (atleast try), unfortunately, the turbo shaft has a lot of play and spills oil everywhere in the hoses ... it's really near from death right now. It isn't (yet) touching the body, but it's getting close ...
However, so far, the Caddy has been running great, no limp mode, we just drive it easy for the engine/turbo's sake, yet it still makes boost and the valve dumps the excess when the turbo is cold/mecanism is stuck.
Unfortunately, a new problem showed up and the ECU sometimes doesn't respond / the car acts like if there was an issue with the immo (starts & stop within a second).
I already replaced the immo with an immo emulator but the problem remains. I've ring'd (is it the accurate word ?) the wiring to the ECU with a multimeter, suspecting an issue with the harness but I haven't found any issue so far.
I opened the ECU, a little moisture invasion and a dry weld but nothing changed, the ECU will still randomly "lose" his mind, preventing him to start the car and the RossTech Cable to communicate.
However I can still diagnose the immobilizer, key is recognized, engine start autorized, etc but "no response from ECU" so ...
That's why, we're considering throwing the ALH away and get a mere 1.9D just to get it reliable -without any power-
Old May 26th, 2017, 16:35   #14
\/\/0J0
\/\/0J0's Avatar
Check your grounds(earths)--especially under the wiper cowl--and your 109 relay to help diagnose the dodgy ecu communication.
I miss my TDi
Old June 1st, 2017, 13:29   #15
casioqv
I'd guess you have either a vacuum leak, or failing vacuum pump causing your boost spike- not quite enough vacuum for the system to work. There are many places for a vacuum leak, and small ones seem to still read a strong vacuum on a gauge, but still cause overboost.
casioqv is offline   Reply With Quote
alh broken valve fix 50harleyrider VW MKIV-A4 TDIs (VE and PD) 1 September 8th, 2015 10:02
Possible to run BEW anti-shudder valve on ALH software? Redneck Truck VW MKIV-A4 TDIs (VE and PD) 10 July 31st, 2013 21:18
Looking for the TDIClub DIY to change 01M trans fluid to fix sketchy shifts dubCanuck1 TDI 101 2 January 20th, 2011 11:54
Dump Valve? Turkster VW B5 Passat TDIs 8 June 21st, 2007 04:59
dump valve ibizaturbo TDI 101 1 May 4th, 2007 18:51
Page generated in 0.19362 seconds with 11 queries
[Output: 139.14 Kb. compressed to 117.91 Kb. by saving 21.23 Kb. (15.26%)]
