Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old February 23rd, 2014, 17:07   #1
ctennyson
TDI(s): 2010 Jetta
Default New Member and Jetta Here
Hello All,
Just purchased a 2010 Jetta 2.0 6 speed manual. I recently gave up on my Audi A3, as was tired of putting in the premium fuel into it every week.
My Jetta as 150K on it and I doubt the timing belt has ever been changed, at what km range should the belt be changed ?
Second question, I like to do my own oil changes. Can I use the same oil as I used to use in the A3. Castrol Syntec 5W40 and how frequent should I change the oil ?
Cheers
Colin
ctennyson is offline   Reply With Quote
Old February 23rd, 2014, 17:16   #2
mrrhtuner
mrrhtuner's Avatar
What KM's should the belt be done at? You just bought the car so get it done.
Check our Shell Rotella T6, very popular here.
Good riddance to the A3 eh?
mrrhtuner is offline   Reply With Quote
Old February 24th, 2014, 07:51   #3
ctennyson
TDI(s): 2010 Jetta
Thanks for the reply.
Yes good riddance to the A3, was never a real fan of that car. Fun car to drive but the costs of repair and maintenance was BIG. I'm not a big guy 5'10" and found it difficult to be getting in and out of.
Looking forward to my first TDi and already thinking some mods.
Happy to find this site also.
Old February 24th, 2014, 08:17   #4
mrrhtuner
mrrhtuner's Avatar
Between this site, google and myturbodiesel.com is all you need
You should look at getting the Timing belt done if you don't know when and who did it last time. Also, the timing belt job requires the water pump (metal impellar), new bolts/seals and rollers FYI.
Old February 24th, 2014, 08:30   #5
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Your car calls for 507.00 oil for both lubrication and chemical composition friendly to your DPF. If that version of Syntec (now called EDGE) is 507.00 it is OK to use. Otherwise you can get oil from Precision Tuning, Brian at Roseland, and some oils at CTC are 507.00 - thread here: http://forums.tdiclub.com/showthread.php?t=395208
As above, get your timing belt changed too.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old February 24th, 2014, 08:33   #6
mrrhtuner
mrrhtuner's Avatar
gahh, I didn't notice his car is a 2010, nevermind the Shell recommendation. Listen to Windex
Old February 24th, 2014, 11:15   #7
ctennyson
TDI(s): 2010 Jetta
Excellent - Thanks Guys
Newbie, member, veteran member designation spuimatt TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 47 November 23rd, 2016 13:25
New member, new Jetta TDI Diezel Dawg Jetta/Bora/Vento TDI Picture Gallery 12 February 3rd, 2012 01:52
New member w/new jetta on its way! rockerdan VW MKVI-A6 Jetta Sedan (~ 2011+) 4 May 28th, 2011 13:06
New Member - Probably buying a Jetta TexasJetta05TDI VW MKIV-A4 TDIs (VE and PD) 15 December 24th, 2004 08:52
new member, new jetta wagon jettapilot Jetta/Bora/Vento TDI Picture Gallery 2 May 14th, 2003 16:37
Page generated in 0.15317 seconds with 11 queries
[Output: 80.26 Kb. compressed to 69.66 Kb. by saving 10.60 Kb. (13.21%)]
