[ QUOTE ]
Sure, that should work but you will need to regulate the pressure to around 15psi. You know that, right?
[/ QUOTE ]
Right - I'll probably just run the compressor long enough to build up to 15 or so psi (rather than fiddle with the regulator).
[ QUOTE ]
The cap is 45mm size.
[/ QUOTE ]
Right - I'm planning to use a GM type cap (Help! p/n 42035) which I saw on:
http://www.audiworld.com/tech/misc24.shtml
[ QUOTE ]
I think I understand your question. You want to pressure the reservoir and pump the pedals at the same time. Is that what you intend?
[/ QUOTE ]
Not exactly - what I think I would do is suck out the old fluid in the reservior, fill with new fluid, open one brake (and clutch) bleed screw, depress the brake and clutch pedals to expel the cylindar fluid, close the bleed screws & release the pedals. At that point, I would proceed with the pressure bleeding.
Thanks for the input - if you have other comments I would appreciate it.
